Bed Camera - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 12 Old 09-23-2011, 07:30 PM Thread Starter
F350SD's Avatar
Bed Camera
Can anyone recommend a manufacturer for a camera that could be mounted behind the cab on the lateral bed rail? Or a good website to look for something like that? I'd like to have something to help when backing towards the 5th wheel RV I tow as sometimes I have to hook up by myself. I already have a monitor (Magnadyne M1-LCD-2.) so I'd just need the camera itself w/associated wiring. Any suggestions would be appreciated. Thanks -
also - the M1 head unit comes prewired to connect to a remotely mounted GPS module and display on the main screen. any ideas on finding something that would work for this would also be great. Thanks again.
- Josh
2015 F450 Platinum (me happy)
Montana 3625RE 5th wheel (wife happy)
USMC 89-93 / Wounded Warrior Project supporter
F350SD is offline
post #2 of 12 Old 09-23-2011, 07:38 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
You could get one that would go on your licence plate bracket and mount it you your head board. Farily common, just google aftermarket backup camera.
There was a member on here that was selling them but not sure where the thread was.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #3 of 12 Old 09-24-2011, 06:53 AM
mor4wd's Avatar
If you've got the factory nav, which I think a King Ranch has stock, then this would offer a much cleaner install without having an additional screen. FORD LOCKPICKS
It lets you add up to 2 additional cameras, which they sell.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #4 of 12 Old 09-24-2011, 08:16 AM Thread Starter
F350SD's Avatar
thanks - i'll check it out. I don't have the factory nav in my King Ranch but already have an aftermarket head unit w/screen (which i'm going to fit-check again right now) which is gps capable. i don't know much about what comes installed from the factory if you don't have the nav option selected - could the truck already have the necessary hardware to run a gps program but just not have it initialized as i didn't get the factory screened head unit? thanks again for any info.
F350SD is offline
post #5 of 12 Old 09-24-2011, 02:58 PM
mor4wd's Avatar
From my experience the trucks are all wired the same but I don't know if they'd run a wire for the GPS antennae.
mor4wd is offline
post #6 of 12 Old 09-24-2011, 05:32 PM
twin200's Avatar
If your putting an aftermarket HU in, there are a few other things your going to need. Is it a double vin. A lot of the double vin have camera capability. tell me your brand and model and I'll try to help or you can go to Crutchfield. com and tell them to outfit your truck
2000 F-350 7.3 4wd cc,dually lariat
afe intake,programmer. rear airbags
2011 F350 6.7 cc,4wd shortbox lariat
Tinted windows Gray bedliner(diy)
Tool box Bull bar
Front aux lights Rear aux lights
Onboard air Train horns
Billet grille LED bed lights
Mike
twin200 is offline
post #7 of 12 Old 10-07-2011, 06:52 PM
4x4ord's Avatar
Quoted: 3 Post(s)
You could save yourself the bother by just sticking a piece of chrome accent panel on the lower nose of your RV. Look in the "mirror" as you back up the truck.
4x4ord is offline
post #8 of 12 Old 12-05-2011, 07:54 AM
Porthole's Avatar
I use a "stick" magnet on the center of the saddle, line that up with the mirror and king pin. As the king pin rides up the saddle it knocks the magnet forward and it drops out of the way.
Thanks,
Duane
First ever blue oval........
2011 F-350 DRW White Tri-coat
2010 3010 Cyclone Toy Hauler
Porthole is offline
post #9 of 12 Old 12-29-2011, 01:35 AM
F350KR's Avatar
i too am wondering if you can buy a factory dvd navi and would it just plug in...? also my buddy and his 05 f150 he did that bought a factory unit and it pluged right in...?? thoughts? thanks 3 thing i wish i would a got on mine is the KR 20's, sunroof, and the factory dvd navi
Had- 2004 F350 CC LB 4x4 6.0 Tuned, 4" Straight Pipe, K&N, LED strobes, Double DIN Dash Mod, 201,653 on the OD
Have- 2012 F350 King Ranch CC, H&S, Straight piped, Whited out grill, Readylift sitting in living room...
F350KR is offline
post #10 of 12 Old 12-29-2011, 02:26 PM
Quoted: 14 Post(s)
I have the Factory Nav and use the camera in tailgate.
I also added Edge CTS, It will also accept a camera, So I put a camera on the back of my trailer, and run the connection to my Edge CTS. So I have two displays. One for each camera.
The Edge CTS besides displaying the camera feed, Also monitors a lot of your trucks vital data.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
