EC130H, Sync will see the 2nd USB and it functions same as the one on the dash. I simply routed the cable inside the glove box and plugged in my 120gb Zune. I now have endless hours of music that is controlled by the Voice command. You can order the cable at any ford dealer. Take the part number, my dealer had some problems locating it. I know others have used different cables that had to be modified, but with the Ford cables costing less than $30, it is the easiest way to go.
I can not find it! Maybe because I am trying to use an Apple USB cable to plug my iPod in? I will get an inspection mirror at work Tuesday and see if I can find it.
Update: I didn't see that it was a mini USB, so I will get the part from my dealer or radio shack, I was thinking dealer because it clips in.
This is awesome!!! I was thinking I would have to run something like a 4 port hub or something. But I didn't want more stuff hanging out of the dash. This works great for my external hard drive. Plug it in and drop it into the glove box. THANKS!!!
BUMP!! This is one thread that I still am enjoying. I am using a 500gb portable drive in my glove box and just used a 8" micro usb to female usb that I bought off of ebay for just a couple bucks. THANKS AGAIN!!!
too bad they don't make a small wireless NAS box that can be powered off the usb port...
How sweet would that be, in-cab network storage and MP3 repository for SYNC.
Sorry I'm kind of a geek, it sure would be handy for transfering music to the device. Setup a scheduled task to copy any new music to the truck when its parked in the driveway... yes.
on second thought I would burn through alot of fuel leaving the truck running overnight for the sync to take place. unless I could build something into the process that after the wireless connection becomes connected or "docked" a syncronization would take place immeditately. If this were possible a syncronization could be acomplished by using the remote start and allowing the truck to idle for a few minutes.
I take it the sync system isn't capable of reading NTFS file system? I tried plugging my portable external into my wife's car, but the usb port didn't have enough power to run it properly.
Correct, the truck will not read NTFS. it must be formatted FAT32 there are a few free utilities that will do this.
I was thinking of syncronizing the HDD with a server in the house, but the truck would need to be on and this would not allow for the server side initiation of the sync. Oh well, I guess I'll have to carry the drive in the house.
I've also found that my truck will not power two of my external harddrives, I've ordered a newer enclosure to see if that will help. The drive I used was an old hitachi 60gb 1.1w drive and a newer .550w WD Scorpio black 500gb, neither will power up properly. hoping it was a powerhungry enclousre... should know tonight or tomorrow. if not my next step will be to try a 5400 RPM drive maybe the 7200 drives require more powah!
I guess I could just go with a couple 64gb memory sticks, but I want to be different I guess. besides I found a mini usb male to male cord from an old wireless headset that just makes it too easy if I can get the HDD to power up.
I've read others being able to power drives with no issues so I don't see a reason it won't work... its just not.
Cable is a pain to plug in because it's shaped differently. The cable from ford is a replacement for the bottom receptacle. The flat corner is opposite on the top USB2. I filed the corner down and it plugged right in!! Works like a champ. Just FYI.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
