I would like to put my Ipod in the lower locking center console on my 2012 F250, not in the glovebox simply because the glovebox on my truck doesn't have a lock. And I use my glove box for, well, gloves. I don't want to have my usb cable hanging out of the dash while parked in public parking lot. The lower locking console in my truck is quite hidden. So I am going to route a cable from the USB plug behind the dash, under the carpet and into my console.
One question I have is: How long is the factory part numbered - cable you are reffering to in this post?
I have the basic My SYNC system. Which does not have the large touch screen, only the 2 line LED readout on the radio. It plays my Ipod perfectly, responds to commands and such like a dream.
Do you see any problem with my plan?
I have an iPod just for the truck, an older "video" 30GB
It is wrapped in foam and stuffed up under the top of the dash, connected to the 2nd USB port.
For you guys who have shoved your Ipod up into the dash, do you just plug it in and leave it on? Does it power down on its own and then starts back up when you start your truck back up?
I had one plugged into my 2005 F150, and if left for 2-3 weeks it would kill the battery flat. Took it out, no trouble after that. Mind you, that was in an aftermarket stereo.
I'm going to get one of these in a 16gb and put all my music on it and leave it plugged into the USB on the dash. That way I have all the song info that you don't have with the Bluetooth connection. It's so small, it will barely be visible.
I don't like to use the USB port to plug in my phone because it doesn't charge the phone very fast and I feel like with the low amperage (or whatever causes it) it will harm my battery.
Could you remove the drive from the truck and then install a larger capacity drive? asI am not even sure what the stock one is, and as far as the software on the drive most electronics stores sell hard drive copy/ cloning devices for about $60 and you could also drag and drop the music in this way. This is what I am considering since i already hay the clone device and hard drives are cheap also that way you could have a "stock" drive if ever needed to put back in .
Does anyone see a problem with this?
and I say use a second cloned drive because who knows what Ford would charge for a $50 drive and some software.
any one know what the size(GB/TB) would be on these trucks?
and it just has to be formatted to FAT32......?
Feel free to comment as I would really like to use a feature that came with my truck (if not make it better also) since the local ford dealer told me the only way to add music is a original cd or possibly a burnt mp3 cd (and not a mp3 DVD asked) he said you would loose the names of artists and such if it was not from a plain store bought cd. Sorry for the rambling but for the cost of the option you should be able to plug something into the usb port and it sucks the music in (or even over bluetooth) .
Lance
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
