Auto Dimming Dash Lights - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 4 Old 04-17-2011, 06:43 AM Thread Starter
Is there a way to keep the dash lights at the brightest setting at night? I am guessing not but thought I'd ask. Thanks.
MaximumSVT is offline
post #2 of 4 Old 04-17-2011, 09:07 AM
Nthorseman's Avatar
You're the second person I've seen ask this odd question. I'd like to be able to make the dash lights dimmer...and that high beam light can burn a hole in your retina...have to get out the window tint to dim it.
I term this an odd question, because the more light 'interference' from the dash lights, the harder it is to see what you really need to see in front of you in the headlights.
So if they can be made brighter, can they be made even dimmer?
2011, F250 Lariat, Green, 4x4, 6.7L, Longbox, SRW, 3.55 gears, Upfitter switches, Moon/Sunroof, Leather seats, High idle, Rapid heater
Nthorseman is offline
post #3 of 4 Old 04-17-2011, 03:41 PM
JackDN's Avatar
Check page 88 of the Owner's Manual and it tells you how to dim or raise the dash light level
2011
F350 6.7L Lariat Ultimate LB CC/DRW 4x4 Golden Bronze/Pale Adobe
JackDN is offline
post #4 of 4 Old 04-19-2011, 07:26 PM
Nthorseman's Avatar
To clarify, by even dimmer, I mean dimmer than they can be set to now.
