LED Bed Lights - what power source? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 12 Old 01-05-2011, 09:25 AM Thread Starter
Hey guys:
I received a free set of PlasmaGlow LED bed lights when I bought my bed cover, and would like to get them set up. I figured out how to run the wires all the way through, into the cab and into the upfitter switch, but the problem there is the key has to be on for it to generate power.
I'd like to tap into maybe the brake light somehow or something else, where I can use a little switch they provide. That way I can just turn it off and on right from the bed. Anyone else done something similar? Any ideas?
Thanx guys....
Larry C
800lbft is offline
post #2 of 12 Old 01-05-2011, 07:09 PM
There is a positive sign on the trailer light plug, you can try it not sure if it would have enough voltage to run them. You could always run a trial wire to it before you hard wire.
pipeliner08 is offline
post #3 of 12 Old 01-07-2011, 06:54 PM
matty21's Avatar
take it off the trailer wiring harness, put a micro pressure switch in the endgate so when you open the gate they turn on.
you can even feed them off of the licence plate lights
and if i remember correctly those led kits only draw 1.5 amps at 14 V DC
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #4 of 12 Old 01-07-2011, 07:34 PM
joec410's Avatar
Quoted: 3 Post(s)
Let us know what you end up doing because I have been looking at these lights. I like the pressure switch idea.
2012 Ford F-250 Lariat, CC, LB, 4x4, 6.7 Powerstroke, 3.55 E-locker, Nav, Chrome BMF Novakanes 20"x9", 305/55-20 BFG AT's
joec410 is offline
post #5 of 12 Old 01-10-2011, 12:43 PM Thread Starter
Good idea Matty - I'm gonna look at that tonight.
800lbft is offline
post #6 of 12 Old 01-13-2011, 02:15 AM
matty21's Avatar
grab one of these or similar.9087 Universal door jamb switch on eBay.ca (item 220603330220 end time 03-Feb-11 21:13:30 EST)
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #7 of 12 Old 01-13-2011, 02:54 AM
MikesF350ps's Avatar
Quoted: 5 Post(s)
Garage
I tap off my dome light and with a door jam switch it works just like open your doors
2007 F-350 4X4, 6.0L, Leveled
ARP Studs, OEM Gasket, EGR Delete, Oil Cooler
EGT, Volt, Water and Fuel Pressure Gauges
MBRP Exhaust w/Cat & Muffler Delete
AVH P 3200 BT with Back up Camera & XM Satellite
High Idle Mod, LEDís All Around ,Viair Air System for Air Horns, XDP Coolant filtration
08 Style Mirrors, Tailgate and Bumper, SCT Livewire TS Amerihood Functional Ram Air Hood with Heat Extractions Vents and S&B Cold Intake
2015 Keystone Montana 3791RD 5th Wheel
MikesF350ps is offline
post #8 of 12 Old 01-13-2011, 04:40 AM
joec410's Avatar
Quoted: 3 Post(s)
Mike,
What type of door jam switch did you use and where did you mount it? Can you post a picture of the switch.
joec410 is offline
post #9 of 12 Old 01-14-2011, 10:08 PM
UNDERCOVER_73's Avatar
This is cake. You can run the HOT + to any type of Powered item u have in or out of the truck that only works when Key is ON. Then use a Switch like they have said^ (Like wats in the door jams) and wire it up, youll have to put a hole in the Sill of the gate for it to work. Then ground it, RUn the lights under the Railsides (screw or Double/sided tape them in) and test them, u should be good to go
Like this ^
-06 F250 SCSB 6.0 191k
TSD Super Panty Dropper
190/100s
Gt4294 Turbo
5" Exhaust
Airaid intake
Studded and Deleted.
50" Led Light Bar
4" lift 37x14s
-04 Crown Vic P71 interceptor 160k
UNDERCOVER_73 is offline
post #10 of 12 Old 02-25-2011, 06:13 PM
joec410's Avatar
Quoted: 3 Post(s)
Larry,
Did you hookup your bed lights yet?
joec410 is offline
