Does anyone know a good way to run a wire from the upfitter switches to the truck bed? Or a good resource to use to find out how?
Currently, I have the wires running under the left side driver and passenger kick plates, out the bottom and up around into the bed through the rubber grommet. There's gotta be a better way.
Take off the plastic kick panel, pull off the plastic trim next to your seat.
Cut of one of the retaining tabs, you can now feed wire down the body through that hole and put the trim back in place.
You can then use the holes in the back of the bed through the stake pockets and into the bed.
Pretty simple...
Pretty simple...
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
