Death wobble fix? - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems 6.7 Drivetrain Problems
 1Likes
  • 1 Post By CT Performance, Inc.
post #1 of 8 Old 06-10-2014, 12:47 PM Thread Starter
Death wobble fix?
Anyone know if these will fit an '11+? They list 05-10 and tech support said they will not recommend them unless they list it for 11
BD Diesel 1032100 BD Diesel Performance Cam Caster Adjuster Kits - Free Shipping on All Orders @ JEGS
I have been cursed with the death wobble and through some research have decided this might be my best bet for trying to fix it. Anyone else got a good solution to this other wise??? New shocks and dual stabilizers will be next on the list if this does not fit.
kdneo is offline
post #2 of 8 Old 06-10-2014, 02:34 PM
matty21's Avatar
If everything is tight and wheels and tires are balanced then ya it's a great thing to do and easy and your going to want it set at ~3 degrees pos castor, no matter if the tire shop says it should only Have 1. Insist on 3
Check the factory stabilizer and don't get sucked into people saying it's the track bar and to get a anti wobble trac bar. That's not the fix
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
http://www.facebook.com/video/video....91500544216050
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 8 Old 06-12-2014, 01:48 PM Thread Starter
So the radius control arms are the same on a 10 and an 11? I called BD and they would not tell me anything other than what the computer screen said to them. Just wanna make sure these will fit before I order them up.
kdneo is offline
post #4 of 8 Old 06-12-2014, 06:17 PM
matty21's Avatar
Same stamped steel radius arms
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #5 of 8 Old 08-06-2014, 11:07 PM
Field Truck's Avatar
On my 2012 DRW F350, I got it professionally aligned to specs(it needed toe in), added HD dampener and set fronts at 60/65psi. Zero issues after that.
Field Truck is offline
post #6 of 8 Old 08-07-2014, 07:46 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Just get castor shims and correct alignment the majority of wobbles is from the lack of castor in these trucks.
Field Truck likes this.
CT Performance, Inc. is offline
post #7 of 8 Old 08-16-2014, 06:18 PM
jrelliott1's Avatar
2011 F350 bad Death Wobble just installed BD adjustable track bar 100% fixed
jrelliott1 is offline
post #8 of 8 Old 08-25-2014, 07:55 AM
edreddy's Avatar
Garage
I had death wobble on my 2013 F350 and it went away all by itself. Mind you, I was having a deathwobble at 3000 miles and was running just an OEM setup.
Anything you put on that changes the alignment (if you're having a deathwobble issue) won't hurt. It's caused by a lack of castor as CT P said. I would be more inclined to get a BD adjustable track bar...
edreddy is offline
