Service advance track, no ABS! - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems 6.7 Drivetrain Problems
post #1 of 5 Old 05-28-2014, 07:01 PM Thread Starter
I decided to take my super duty into a little mud, the 4x4 is nothing like my old chev or dodge. I had to stop the truck or a warning would come up saying 4x4 was being delayed at speeds exceeding 5km/h.
Once the 4x4 was finally engaged, I locked the front hubs. I got 10 feet into the mud and gave the truck some throttle and the advance track and abs light lit up!
The truck used to flawlessly perform posi-tire spin, now only the passenger tire turns.
My truck is tuned and deleted, I'm just worried if I take the truck to the dealer, they will reset the computer and my programmer won't work or something.
Any advice?
2012 6.7L F-350 4x4, XLT EC/LB SRW
Done april/2014-
Used SPARTAN dashdaq-XL, AFE intake, and 4" straight pipe exhaust (DPF deleted)...
Mods to come:
EGR delete
36x15.50R20's with -44 offset rims and a lift to accommodate!
Located in Ontario!
x-SYOTOS-x is offline
post #2 of 5 Old 05-28-2014, 07:31 PM
sbluke55's Avatar
Quoted: 341 Post(s)
Garage
I've had that happen to my 2014 gasser. I've cycled the key and it went away. I don't know what caused it. FYI to turn of advanced trac press and hold your traction control button (5-10 seconds) tell it says "advanced trac off" on the dash. It really helps in the mud. Plus you can set the truck sideways without having to truck trying to straighten you back out.
01 f-250, Standard
Rev tech 4" lift,35" Mickey Thompsons MTZ
KC diy 66 stage 2, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 5 Old 05-28-2014, 08:04 PM Thread Starter
Thanks for the reply!
I had the advance track off at the time, burn outs are absolutely insane when you turn it off! Nothing like rolling sideways at 55mph!
I cycled the key, cleared codes using the SPARTAN, nothing.
I can't make any adjustments to my advance track systems ATM because of the warning...
So I'm thinking the next step is to take to the dealer, but I don't want them to flash my truck computer to stock while my tuner is programmed to the 165, I fear It will make my tuner useless and make my truck run like crap since the DPF is deleted
Done april/2014-
Mods to come:
EGR delete
Located in Ontario!
post #4 of 5 Old 05-29-2014, 06:18 PM Thread Starter
Fixed the issue!
Ripped the front abs sensor off... Lol
Apparently the abs is connected to the advance track, because once I replaced the sensor, the advance track was working!
Done april/2014-
Mods to come:
EGR delete
Located in Ontario!
post #5 of 5 Old 11-20-2014, 09:32 PM
Mitch925's Avatar
Quoted: 3 Post(s)
when you applied the brakes did your truck want to pull hard to one side? and did you feel your brake pedal shake and hear and raddling sound coming from under the dash/hood near the Master cylinder?
Mitch925 is offline
