Low Speed Tire Rubbing Sound - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems 6.7 Drivetrain Problems
User Tag List
post #1 of 31 Old 03-10-2014, 09:07 AM Thread Starter
So the new 2014 I've got has a rubbing noise at low speed turns or bends in the road. It only takes 1/4 turn of the steering wheel to feel it.
I asked the GM of the dealership about it and he said might have something to do with the ABS and might be normal? I don't see how this is possible but I know stuff is hard to diagnose over the phone.
I had them install a 2" leveling kit so it has the plastic spacer above the front springs. I know it's not a tire rubbing (stock tires) but feels just like it. Also, if my brakes happen to be applied i can feel it through the brake pedal.
I've removed the front tires and visually checked all I can, and turned the wheels slightly while inspecting from under the truck. The only thing i've found remotely close to rubbing is the drivers side sway bar link being at an imperfect angle due to the spacers. Might loosen those up and drive to see if there's a difference but I think that's a shot in the dark.
Anyone else experience this?
99.5 F250 LWB SRW Crew Cab 420K+ miles
this truck was the WINNER of the 2013 Tough Truck Challenge by Ford Commercial Vehicles Division! that's how we got the '14!
'14 F350 LWB SRW Crew Cab Lariat
azul grande is offline
The Following User Says Thank You to azul grande For This Useful Post:
dt.2448 (03-12-2014)
post #2 of 31 Old 03-11-2014, 10:58 AM
fordtrix's Avatar
you need to have someone in the truck, and have them slowly drive and make it do whatever it's doing (rubbing if that's the case) and you'll be able to walk by it and inspect to see what it's rubbing. Could be a number of things.
Worse case scenario just make an appointment and bring it in. It's under warranty.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #3 of 31 Old 03-11-2014, 12:10 PM
sbluke55's Avatar
Quoted: 308 Post(s)
I would have the alignment checked.
01 f-250, Standard
Rev tech 4" lift,35" Mickey Thompsons MTZ
KC diy 66 stage 2, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 31 Old 03-12-2014, 11:04 AM
Alberta Advantage's Avatar
Quoted: 17 Post(s)
If you have mud flaps on your truck, your tires could be hitting them when you're turning. I ended up having to use aircraft cable and some fittings to pull the mud flaps back from the tires.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
The Following User Says Thank You to Alberta Advantage For This Useful Post:
post #5 of 31 Old 03-12-2014, 04:33 PM
I have a 14 F-350 and have noticed I too have a rubbing when I turn on the road I live on. I held the mud flaps suspect, I will follow up on this..
Thanks to O.P. & A.A.
dt.2448 is offline
post #6 of 31 Old 03-13-2014, 08:16 AM
ciscofreak's Avatar
My truck has done the exact same thing since new and I have no mud flaps. I'm not sure why either.
13 F350 Lariat CC LWB
ciscofreak is offline
post #7 of 31 Old 03-13-2014, 09:57 AM
Quoted: 17 Post(s)
Could be the inner wheel well mud/dirt protector moving around while you're turning or going over bumps. The screws in mine were stripped out on my truck and it would move around causing rubbing. My mudflaps also pulled the wheel well liner more towards the tires too since they weren't solidly anchored.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #8 of 31 Old 03-17-2014, 05:47 AM Thread Starter
i'm thinking that the dealer was right with his ABS theory, it seems to have less to do with turning the wheel (we're talking a quarter turn, basically nothing) and more to do with body roll when making said turn. i have even felt it "rub" going straight down the road.
stock tires, no mud flaps, 2" leveling kit. these tires are no where near anything.
post #9 of 31 Old 03-28-2014, 07:34 PM
Could it not be the sway control? Thoughts?
dt.2448 is offline
post #10 of 31 Old 03-29-2014, 08:57 PM
STX79's Avatar
I noticed this to the first week I had the truck too, also have a 2" leveling kit. I flexed the truck every way possible and couldn't make the tires rub, it has to be the ABS or Sway Control. I'm not sure if you have to be connected to a trailer for the Sway Control to work?
2014 F350 SRW Platinum, Ranch Hand bumpers, AMP Steps, BDS 2" leveling kit, Bilstein 5100 Shocks, 35x12.50R20 Toyo Mud Terrains.
STX79 is offline
