Popping Noise In Front End While Turning - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems 6.7 Drivetrain Problems
post #1 of 10 Old 11-17-2013, 03:27 PM Thread Starter
hcfd63's Avatar
I'm getting a singular popping noise in the front end during slow speed turning. Noise just started, but have had a ready lift 2.5" leveling kit on the truck for 3 months, with stock size BFG A/T tires.
Seems to do it while turning left or right - and doesn't have to be full lock turning.
Truck has 31,000 miles and except for the leveling kit total stock.
It has been fairly wet the last two days, so I haven't had a chance to crawl under it to see if anything is obvious. But any thoughts anyone has, I would appreciate.
2011 F-350 CCLB SRW King Ranch 4x4
hcfd63 is offline
post #2 of 10 Old 11-17-2013, 03:41 PM
STANGMAN893's Avatar
My buddies 11 did that from day1 of its life. Turned out to be a cab mount and it had a tsb for it.
STANGMAN893 is offline
post #3 of 10 Old 11-17-2013, 05:55 PM
Quoted: 2 Post(s)
Ya check the cab mounts. Loosen them or remove the bolt completely from one and see if the noise goes away. I had to do this on my 06 GMC Duramax
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 10 Old 11-17-2013, 06:29 PM
Mine does this too but only when it's wet outside. What exactly should we check the mounts for? To see if they're loose?
Sent from AutoGuide.com App
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
post #5 of 10 Old 11-17-2013, 06:34 PM
Quoted: 2 Post(s)
Could be overtight or ****ed. I would loosen to see if noise goes away then re-torque.
wreedPS is offline
post #6 of 10 Old 11-18-2013, 04:19 AM Thread Starter
hcfd63's Avatar
Took a quick look this morning. In my case I don't think it has anything to do with the body mounts. Looks like the jam bolts on the drag link are hitting the sway bar when the wheel is turned, and there is a little bit of body roll. Not sure how it happened, but the drag link adjustment has come out of the lock. See the photos. The angle of the shots makes it look like it will always hit - but on flat ground it will clear, just barely.
Uploaded with ImageShack.com
hcfd63 is offline
post #7 of 10 Old 11-18-2013, 04:30 AM
I'll have to take a look at that. Mine is lifted 4.5 inches but I guess if everything is dropped down to be like stock then it'll hit too.
I didn't think it was something with the body mounts because I can watch my tire while I turn and when it pops the tire kind of jumps like something was binding in the steering.
DillonC is offline
post #8 of 10 Old 11-18-2013, 04:43 AM Thread Starter
hcfd63's Avatar
My sway bar is dropped down to compensate for the level kit. Hadn't really studied it, but I'm guessing so long as those bolts aren't sticking straight up on the draglink then there should be clearance. I need an alignment anyway, so I'll get them to check it all out anyway.
hcfd63 is offline
post #9 of 10 Old 01-04-2014, 07:38 AM
Kinda think mine does this as well. Almost sounds like something is loose when it makes the noise. Only does it every so often on a couple of different turns.
2012 CCLB F250 Lariat 4x4 6.7L
Rigid Industries 20" E-Series-Husky Liners-S&B Intake
Pure Performance 4" Triple Threat-PMF Dual Steering Stabilizer-Method NV-315 70R18 Toyo M/Ts
5-0stank is offline
post #10 of 10 Old 01-05-2014, 04:08 AM
OneTon2011's Avatar
Quoted: 11 Post(s)
Another place you may wanna check is the nut on the pitman arm (connection to steering box). Mine had backed off some and was causing it make a popping sound while turning. I tightend the nut and bought a new nut and used some lock tight, and all is good now.
Shawn - 2011 Super Duty 6.7L Lariat
Oxford White / Sterling Grey two tone
SUSPENSION UNDER CONSTRUCTION!!!!
SS M-16 40x14.50r22 / 22x12 Gear Alloy BIG BLOCK
YUKON 4:30 / MONSTER HOOKS
AMP RESEARCH / RIGID / RECON
PMF / BUSHWACKER / AFE CAI
H&S MINI MAXX / H&S DELETE / ARE
FLO-PRO / PLAIN N SIMPLE / ROAD ARMOR
OneTon2011 is offline
