Driveline - metal popping noise - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems 6.7 Drivetrain Problems
Old 03-31-2011, 07:27 PM
Would pop from dead stop to start of acceleration. Dealer diagnosed the sound was generated from the drive shaft internally. Replaced the driveshaft and all is well so far. 4300 mi.
Old 04-02-2011, 05:49 AM
Probably a bad u-joint or loose slip yoke. Good to hear that they treated you right.
Old 04-02-2011, 09:54 AM
Thought u-joint too but was they proved that was not it. They stated something internal??
Old 07-11-2011, 06:03 PM
there is a tsb about this. I'll try to find it. Ask your dealer too.
Old 09-23-2011, 11:35 AM
Send a message via AIM to gldubzakjr Send a message via Skype™ to gldubzakjr
I have the exact same issue. Over four visits to the dealer, this time they are replacing the drive shaft after getting Ford Engineering involved. It's been on order for several weeks now. Does anyone know the TSB number and have a copy of the details?
Old 09-29-2011, 07:54 PM
The drive shaft wad replaced the other day and now the noise is gone. The tech said he could hear something rolling around inside the old drive shaft.
Old 10-15-2011, 05:30 PM
First 6.7 PS Destroyer
Mine used to do the same thing, now it's gone and hasn't done it in a while.
Old 11-14-2011, 06:22 AM
Just came over to the powerstroke side. 2012 KR F250 4x4, mine has 800 miles on it and I have noticed mine does it as well. At first I thought it was something I had in the bed of the truck. Cleaned everything out and it still does it. Does anyone know the TSB # for it.
PS came over from the cummins side, just could not support the guys that took the bailout. Engine seems a lot more complicated when you pop the hood. (kinda scary) other than that love the truck, lot better ride, lots more power, very smooth.
Old 08-27-2012, 02:05 PM
I've been having the same issue, however, I'm deleted and chipped so I don't want to go to the dealer. Anyone order a performance drive shaft online? (there isn't a shop local to me)
