Tin can sound - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
post #1 of 7 Old 05-03-2014, 06:25 PM Thread Starter
dantry's Avatar
Send a message via AIM to dantry
Tin can sound
2011 Ff250 4x4 has a 4.5 inch lift but I have heard this noise in the past before I lifted it. Sounds like it's coming from the front end. Almost sounds as if I am dragging some tin cans. Its only noticeable from a dead stop and low speeds. Not sure if faster speeds just hide the sound or what. Does not make sound unless truck is moving.
I also Crawled underneath and cannot see anything that stands out of place. Can't figure out what it could be. Thanks for any insight if possible. And questions that could give you more info please ask.
2011 F-250 Crew Cab. 6.7.
-Bone stock for now
dantry is offline
post #2 of 7 Old 05-05-2014, 02:14 PM
LORD OF WAR
nelson1each's Avatar
Feedback Score: 4 reviews
Check the track bar mount bolts and the track bar bolts...especially the upper track bar bolt that thing has a ridiculous tq value
87,96,04 F150 gone
2011 F250 6.7L SC Lariat 4x4
"The War Wagon"
5" Flo Pro w/muffler, SDP downpipe, Sinister EGR delete, S&B intake, H&S mini maxx w/ SPE HotX, H&S intercooler pipe, MPD CCV Mod, Top Gun Customz 6" Lift, TGC dual steering stabilizer w/ night hawk shocks, TGC ladder bars, Night hawk 2.65 resi shocks, BMF rehab 20x9 rims with 5" backspacing (0 offset), Nitto Trail Grappler 37x12.50x20 tires, SSBC calipers w/Big Bite rotors front & rear, SPE metal oil pan upgrade & full diff lock, Mag-hytech dif cover, Deezee headache rack, Bushwacker fender flares & shocker 540 train horns.
nelson1each is offline
post #3 of 7 Old 09-22-2014, 09:16 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
Take your center caps off your wheels turn em and re install and your noise will vanish !! PS im not joking give it a shot
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #4 of 7 Old 09-23-2014, 04:59 AM
fordtrix's Avatar
Sounds just like the problem I mentioned in the thread below this my lug nut fell off, was stuck in center cap, made that "tin can crunching sound" hahaha...
As stupid as it sounds, it seriously could be it.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #5 of 7 Old 09-23-2014, 08:27 AM
2013F250Tank's Avatar
My 2013 250 with 26k miles is making a similar noise(open exhaust no heat shields). tin can or heat shield rattle. Happens just over 1100 rpm no center caps, lugs an track bar are tight.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #6 of 7 Old 10-24-2015, 09:25 AM
Did anyone figure out what this issue was yet? I've had the same issue with my 11 deleted n aftermarket wheels, my buddies 12 with wheels also no caps but has stock exhuast has also started doing it. Only does it 5 to 10mph or reverse. Scratching our heads for months now n nobody can figure it out also doesn't do it all the time either. Sounds just like said above pop cans or a tinny sound or like drum brakes that fell apart
bigdad112 is offline
post #7 of 7 Old 10-25-2015, 04:32 AM
2016 Magnetic F250's Avatar
Quoted: 27 Post(s)
I had a 2008 E350 do this several years ago. I have a 2014 E350 KUV doing this now. It was the front brake pads on the 2008. I now know what the sound is so I have not addressed it on my 14. It's my company truck. The mechanic explained there is a issue with a spring on the back of the pads that is to keep them from moving/rattling. Applies slight pressure just to keep them snug. They changed the pads and it went away. I only have 600 miles on my F250 which is my personal truck so if I hear it I will take the pads off and see if I can adjust/bend this spring to get it to stop, or I will change them. The noise I've had on the E350's were with the factory installed pads that were on the truck when they were new. Bet that's your problem.
2016 Magnetic F250 is offline
