Intermittent Shake Shimmy Vibration Shudder - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
post #1 of 9 Old 01-09-2014, 07:34 AM Thread Starter
jacobdewey's Avatar
UPDATE, Vibration caused by BMF Wheels
I have a really annoying shudder from 65mph+. It will shudder for 10 seconds then kind of let up for 10, then come back.... anyway, it pulsates like that.
I thought my tires were out of balance so I had them balanced... not that. I figured I may have had a seperation of my tread, and it was time for new tires anyway, so I got new tires.... still a vibration. I wondered if a rim was shot so I bought new rims.... Still a vibration.
I thought It might have been a transmission shudder, so I shifted down to 5th to see if the vibration would change. Nope.
Brakes seem smooth and I feel no pulsing or vibration when I use them.
Only two things I have left that I can think of is a unbalanced driveline or a goofy alignment problem. Any input or idea's would be helpful.
2011 CCSB, 20x9 -12mm Badlands, H&S, S&B, Katzkin, DDM 5k, 1.5" leveling kit, 35" AT II's.
jacobdewey is offline
post #2 of 9 Old 01-18-2014, 12:39 PM Thread Starter
jacobdewey's Avatar
I think im going to get my driveline balanced and try a heavier weight oil In The rear diff. We'll see what happens.
post #3 of 9 Old 01-18-2014, 12:56 PM
boatpilot's Avatar
mine does it at 45 mph and only at 45...freaking weird...
2012 F350 KR
Carli 4.5 Performance, Machined Fuel Kranks 17", 37" Toyo MT's, H&S Mini with custom tunes, H&S Cac, S&B CAI, 5" FLOPRO, EGR/DPF delete, Full replacement front and rear bumpers, toolbox, and bedrails by South Texas Outfitters, Rigid LED's, B&W hitches...and this thing is finished!
boatpilot is offline
post #4 of 9 Old 01-18-2014, 01:01 PM Thread Starter
jacobdewey's Avatar
I found this video and It's really similar to what my stroker does. read the comments.
post #5 of 9 Old 01-18-2014, 01:08 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
It's just your truck gettin' Jiggy with your tunes!
Sorry, I wish I could help ya out. Good luck and keep us posted.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 9 Old 01-19-2014, 10:26 AM
Just a shot in the dark, but I've read a little about the "death wobble." Sounds like it could be the problem. You'll have to search around a bit to find symptoms that others have had....I don't have any first hand experience with it.
hilton850 is offline
post #7 of 9 Old 01-19-2014, 11:16 AM
hoofdoctor's Avatar
My 2008 does the same thing at around 72+ MPH. It feels like its in the right rear. Went through the balance the wheels thing and nothing. Will be checking the balance of the drive shaft next.
Just for the record my truck is a 2008 4X4 super cab long box dually.
hoofdoctor is offline
post #8 of 9 Old 01-20-2014, 09:05 AM
loran45's Avatar
Just took mine in for the same thing , the dealership found it was the front track bar bushing went bad. and my truck is a 2012 KR F-350 SRW short bed with 12,000 on it, hope this helps.
loran45 is offline
post #9 of 9 Old 03-07-2014, 12:32 PM Thread Starter
jacobdewey's Avatar
UPDATE!!
Turns out it was these stupid BMF wheels all along. The third time that I was getting them balanced, the tech had me come and look at my wheels as they spun on the machine. 2/4 of the wheels have a crooked center and wobble a good 1/4 to 1/2" as they spin on the machine. The other two were perfect. He put them on the machine twice to double check. He said he usually only see's this on crappy cheap wheels. For the price I paid for these BMF's, they shouldn't be a crappy wheel!!!!!
I ordered some XD's since I've had them on several of my rigs with no issues.
I'm Pissed!!!!
