Noise while braking and turning right - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
post #1 of 13 Old 08-13-2013, 06:06 PM Thread Starter
kirbybc12's Avatar
I've noticed a grinding type of noise while braking and turning right, not remotely close to full lock and coming from the right side of the vehicle. I'm also feeling a lot of slack in the braking pressure on the pedal (which I shouldn't with 27,000 miles of little to no trailering or hard braking). Had a new power steering pump installed about 10,000 miles ago.
I'm thinking that the grinding noise could be a bad ball joint? Although I don't see how it's linked to the brake issue, unless it's unrelated. The only other think I can think of is maybe a warped rotor.
Any other suggestions?
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #2 of 13 Old 04-25-2014, 07:31 PM
DIGMAR's Avatar
Quoted: 26 Post(s)
I'm having the same issue with mine: 2012 F250 with 25,000mi. Any update on what you found?
DIGMAR is offline
post #3 of 13 Old 04-29-2014, 09:35 AM
Quoted: 2 Post(s)
Maybe a failing locking hub?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 13 Old 04-29-2014, 10:52 AM Thread Starter
kirbybc12's Avatar
Still get it, never figured out why. The dealer said something about the hubs a while ago but I don't remember what. Haven't had any hub issues other than the vacuum lines. I just turn up my music and pretend its not there. Going to try taking off my front mud flaps to see if it makes a difference
2.5" Carli Commuter
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
post #5 of 13 Old 04-29-2014, 05:26 PM
DIGMAR's Avatar
Quoted: 26 Post(s)
I get the usual dealer response... It's probably nothing. Just noticed it on the drivers side as well. Hoping whatever it is it fails in the next 11,000 mi. My luck it'll go at 37k.... Just out of warranty
DIGMAR is offline
post #6 of 13 Old 04-29-2014, 06:19 PM
I've had the same thing. '13 10k miles. Been doing it since atleast 4k miles
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #7 of 13 Old 07-28-2014, 05:34 PM
i am having the same problem , i am at 123,000 miles . i replaced rotors and pads last week . the right side was making the noises before i replaced both sides . it is driving me wild . i took the rotors and pads back off , to see if there was any rubbing and there is not . im lost and annoyed . have any of yall had any luck ?
lhood6.7 is offline
post #8 of 13 Old 07-29-2014, 02:18 PM Thread Starter
kirbybc12's Avatar
Never found out. Still doing it, when the dealership checked they gave me some line about hubs and never mentioned it again.
2.5" Carli Commuter
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
post #9 of 13 Old 07-29-2014, 03:54 PM
DIGMAR's Avatar
Quoted: 26 Post(s)
Nope... Just make left hand turns!!! Haha. Same thing. No clue at dealer. I'm at 31k and been doing it since new.
DIGMAR is offline
post #10 of 13 Old 02-07-2015, 06:02 PM
Mine does the same thing but only when turning left. I posted about a year ago to see if anyone else was having the same issue but didn't get any responses. I think it has something to do with the ABS.
sevobuck is offline
