1300-1400 RPM Vibration? - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
post #1 of 6 Old 02-02-2013, 06:38 AM Thread Starter
rvdb's Avatar
Hi, First off I am new to the site & appreciate any input, I picked up a 2012 F350, 4x4 CC, LB, a month ago and I am in need of help, I searched the site, asked questions on other threads with no luck.
I have a vibration at 1300-1400 RPM roughly in between 35 to 45 miles an hour, I am sure its driveline related due to how the vibration comes about.
Ford replaced the drive shaft and balanced the exhaust and checked/balanced the tires.
The problem still persist, I was sent out the door per Ford. I have 800 miles on it and really like the truck however I feel this will lead to premature wear of components not to mention when I break it in & start towing 12k lbs.
Questions; has anyone dealt with this, does it get worse or stay the same?
I am very disappointed in this product at the moment, and am frustrated, thanks for your time.
rvdb is offline
post #2 of 6 Old 03-01-2013, 07:50 AM
It seems to be somewhat common at around 40-45.
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
post #3 of 6 Old 03-07-2013, 07:04 PM
Replace the Steering Stabilizer.... Mine did the same thing and my buddy who is a ford mechanic said to replace the stabilizer, I did and the vibration stopped... Not to say that this will fix your problem, but it fixed mine.... Just something to keep in mind...
Flooded Timber Flowback is offline
post #4 of 6 Old 03-09-2013, 06:29 AM Thread Starter
rvdb's Avatar
Thanks, was it vibrating at a specific RPM? so far, they replaced the torque converter & drive shaft so far and it still does it.I bugs me to think I may have to settle on a new truck that vibrates....
rvdb is offline
post #5 of 6 Old 03-09-2013, 10:23 AM
Seems ford will do only so much then your dumped.Even after the mechanic went with them.Maybe afaid of his job.Indircctly was told to turn the radio up.
bwanted is offline
post #6 of 6 Old 04-04-2013, 08:55 PM
Mine did it when towing backhoe and on the gas... put a larger/heavier duty carrier bearing on drive shaft and mine quit. Bearing was $60. My truck is 2012 F350 Lariat 4X4 CREW CAB DRW now with 13,000 miles. Mine started at around 1200 miles
Todd6.7stroker is offline
Tags
harmonic vibration
