Engaging 4 x 4 on the fly and popping sound - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
post #1 of 22 Old 02-10-2012, 08:08 PM Thread Starter
Haven't had much snow here in the Cheeseland this winter, but tonight I had to drive in it, while driving I engaged the 4 x 4 on the fly... I was doing around 35 or so, and I heard a pop or clunk I guess as it engaged, but it seemed like it was only from the driver's side. Got through the rough open field areas, into the city and back into 2WD. On the way home, the same thing. While driving I'm also hearing a droning sound from the front end with the 4WD engaged.
This is my first Superduty and not sure if any of this is normal or not. I checked the locked outs and they both appear to be in the unlocked position. I've had 4 x 4 trucks most of my life and I can't ever recall a snapping or popping noise when the 4x4 engages on any of my other trucks... I've had all of the big 3.
Any ideas?
2011 F250 FX4 Lariat Ultimate Edition Crew Cab. 3.55 Gears, 20 Inch Wheels , 5 inch Chrome Tubes, Black Tuxedo Paint, Truxedo Soft Tonneau Cover and for the WI Winters, Rapid heat Supplemental Cab heat
Fubs is offline
post #2 of 22 Old 02-11-2012, 04:39 AM
Scubamax's Avatar
My truck is still very new, but I can tell you that my 05 Dmax made some poping almost every time it went into 4wd. My new ford makes "some" noise, but.... Not what you are talking about. I'm sure it's nothing, but If it were to get worse, I'd have the dealer take a look.
Scubamax is offline
post #3 of 22 Old 02-11-2012, 06:52 AM Thread Starter
Thanks, I'll keep an eye on it. I have a 2000 Expedition Eddie Bauer we bought when the kid was young and It never makes any noise going in our out... but it is sort of always in with the Auto 4wd. I have a Company Vehicle that's a 2009 Trailblazer, no noise. My Dodge was a 97 and I can't remember any noise. My Chevy, well was an oldie.. 77 and it didn't make any noise that I could hear over the side pipes and built 350 LOL. I just want to check with the folks in the know, spent too much on my SD and don't want to have issues.
Fubs is offline
post #4 of 22 Old 02-11-2012, 11:54 AM
matty21's Avatar
they all do it. not to worry. its a super duty truck not a little suv. the transfercase is a tad beafier
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #5 of 22 Old 01-01-2013, 09:56 PM
You are very likely going to need hubs. They are a problem with these trucks. Mine is going in for warranty hubs on the 10th with 8000 km. They never clunked in until one day, then every time, then a growl....
I think integrated hub/actuators is going to bite ford in the arse, then us when off warranty.
Take a stand today, join your local Fire Department or First Responder/Rescue team. We need all the help we can find!
Ken2012f350 is offline
post #6 of 22 Old 01-11-2013, 05:14 PM
Suzuki6mx's Avatar
I do know that, if your traveling at any speed, and your rear wheels are losing any traction and spinning there will be a pop or slam into 4x4. Think about it, if your rearend is spinning technically doing 40 while your front end is doing 35 then its gonna slam into gear. I usually try to slow down if possible and then engage 4x4. or go to neutral at higher speed
2002 F350 ext cab SRW 6 1/2' bed(mine)
2008 F350 CC DRW 8' bed(Dads)
2012 Reg Cab DRW Dump
1996 Reg Cab DRW Dump
1999 Reg Cab DRW Dump (After a year of sitting its back and running good)
2003 Ext Cab DRW 8' Utilty
Suzuki6mx is offline
post #7 of 22 Old 01-11-2013, 05:56 PM
Oh no kidding, foot off the gas, coasting prior to engaging is a must.
post #8 of 22 Old 01-11-2013, 09:52 PM
ruizhernandeztrust's Avatar
Location: The place where the 2nd amendment is considered illegal.
I don't own a 6.7L but when I put the 4x4 in my 6.4L it didn't make any noises or strange pops sounds, just a smooth engage
Nelson
__________________
2005 Pontiac GTO (1 of 645) (LS2 6.0L, 6 speed manual / 3.46 gear) 39k miles
2007 F-250 XLT (6.0L, 2wd, 6 speed manual / 3.73 gear) 42k miles
2008 F-450 LARIAT (6.4L, 4x4, 6 speed manual / 4.88 gear) 38k miles
ruizhernandeztrust is offline
post #9 of 22 Old 01-11-2013, 10:24 PM
Mine didn't either when it was new. After driving an hour there, them doing 'warranty diagnostics' for an hour, then driving home again with the same hubs, I am waiting for authorization to waste another 3 hours so they can repeat the process.
post #10 of 22 Old 01-12-2013, 05:50 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I have the manual locking hubs and have never had this issue, this is my second winter here in ohio using 4x4 and problem free thus far. Hope you get it figured out.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
