Front end clunking and buzzing noise during extreme cold - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
post #1 of 5 Old 01-19-2012, 08:15 AM Thread Starter
Been fairly cold here the past few days, yesterday was -26C/-15F and my truck sat at the office for a few hours in the morning and again in the afternoon. When I drove it home for lunch it started making a buzzing noise that sounded just like the mudflaps were caught in the tires, I stopped right away before I ripped off the mudflaps and walked around the truck...nothing, mudflaps weren't the problem. So I started driving again and same thing but add in some fierce clunking noises from the front end...exact same clunk that the 4x4 makes when it shifts in hard, did about 3 or 4 quick clunks and then it all stopped after 2 minute of driving. On the drive home for supper, same thing happened. This morning, again it's pretty cold -26C/-15F, exact same thing and then it stops after a minute or two.
The other weird cold weather noise I've heard is a popping noise coming from behind me, sounds like the frame is shifting like a huge load is in the back but the truck is empty, happens going up or down logging roads...doesn't happen that much but it's a loud pop when it does occur.
CoveShocker is offline
post #2 of 5 Old 01-19-2012, 08:16 PM Thread Starter
Got it back from the dealer this afternoon after letting the truck soak in the cold for most of the day. Turns out the thumping and clunking from the front end are the hubs spontaneously trying to lock in. Apparently Ford is working on a TSB to deal with the hubs trying to lock in when the temps are below -17C. The temporary solution for now: when the temps are below -12C, I'm supposed to manually lock in the hubs so they don't self destruct when it gets colder.
post #3 of 5 Old 01-23-2012, 06:13 PM
grooveman's Avatar
Other noises aside, is it normal to get a pretty loud "clunk" when the 4wd is engaged during extreme cold weather? I do hear that with mine, but it seems to be locking in and running fine after 4wd is engaged.
grooveman is offline
post #4 of 5 Old 01-24-2012, 03:46 PM Thread Starter
I'm told it's normal to have that "clunk" under normal circumstances. In my work I use 4x4 at least once or twice a day from Nov to April....so I sure hope it's normal otherwise it's going to have a short life.
post #5 of 5 Old 12-21-2016, 09:00 PM
Did you ever get a resolution for this issue? I am having the same issues on my 2011 f250 during very cold weather as well. When coming to a stop the front end will whine then clunk just before stopping. The dealer said they are not sure what the cause is, but to prevent damage I should lock the hubs in cold weather. This is a bandage and not a fix for the problem. Has anyone else resolved this issue? I have 210,000 kms on the truck and this has been happening the entire life of the truck. Is there a TSB from Ford on this issue?
winkcon is offline
