Popping during takeoff and bumps - Page 2 - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
 1Likes
post #11 of 14 Old 02-03-2017, 09:41 AM Thread Starter
Quoted: 4 Post(s)
Originally Posted by Maryland dieselnick View Post
Appears we posted same time.
With regards to,"hey the shop will tell you", hate seeing boys going in blind to a shop. Envey of those who can is one issue... but if even he can try to diagnose as such, he is better informed and can quickly weed through a service writer's call sayin,"Mr. Harry Homeowner, your differential is bad" or similar.
I try to look at the glass as half full. Are all service writers honest, no. But how far should my suspicions and paranoia go? I could be worried that they might be sabotaging something else and feel the need to keep the truck under 24/7 surveillance.
I was pretty sure it was drivetrain in the front drivers side area, and was leaning towards sway bar link. So if they were to explain that my differential was bad, it wouldn't fly.
I had pretty good faith in the shop going in, shop had great yelp reviews. Place was kept up, mostly trucks were coming in, and didn't have a stack of vehicles that looked like a junkyard.
Lone Star automotive in Midland, TX was the shop I used. Home is 500 miles away, and I don't really have a shop I use there (do things myself).
I'm still not sure how the driveshaft relates. I'm guessing you were just passing along some information? But yes, I have been pretty happy with the truck overall. It's been better to me than I to it.
Sent from my iPhone using Tapatalk
ropegun2k is offline
post #12 of 14 Old 02-03-2017, 06:38 PM
Quoted: 155 Post(s)
Garage
Did this problem get tracked down yet?
Could be drive line. BUT, You said it also happens on bumps?
My 2011 at 9?,000 miles started to have a rattle, knock metal sound when going over bumps and starting/stopping. It was my Front u-joints at the tires. Pain in the arse to change. about $800 for a local friend of mine to do it. you can easily check this by crawling under and inspecting the U-joints on the 4x4 driveshafts on the tire side. If they are loose and easily move around by hand or long flat head. That is your problem.
2011 Ford F-250 Super Duty Lariat
3.31 ELOD 4X4 6.7 Power stroke
01/24/2017 110,000 MI
S&B CAI
SCT X4 Tuner
Running a tow tune by AMDP
( on-demand exhaust brake from the AMDP tune).LED interior,LED AUX back-up,Westin HDX grill guard,High-idle,Aux 55 Gal Transfer tank,Draw-Tite Hide-A-Hitch gooseneck,LED puddle lights.4000x2 LED lights up front for dark country roads. Access Low profile bed cover.
Roof clearance lights.
mwe_060 is offline
post #13 of 14 Old 02-03-2017, 07:36 PM Thread Starter
Quoted: 4 Post(s)
Yes, see second post. Loose shock bolt.
Thinking about it now, I'm probably wrong but I consider steering/suspension stuff as drivetrain.
In my defense, when I used to work at oreilly auto parts (10 years ago) you would find suspension stuff under that category.
I'm surprised your front ujoints went out, I didn't think they saw rotation when the hubs were not locked.
post #14 of 14 Old 02-03-2017, 07:42 PM
Quoted: 155 Post(s)
Garage
the truck lived on a gravel and off roads for the first 50k of its life in 4x4 50% of the time.
Heck i keep it about the same ratio during spring an fall.
S&B CAI
SCT X4 Tuner
mwe_060 is offline
