| 6.4L Problems Forum Having Trouble? Post here |
HELP DPF sensor!
i got my delete pipe in today and i cant get the egt sensor out of the rear of DPF i got all the other sensors out fine has anyone ran into this problem
i cant move the truck till i get this puppy in its no start
bump...........
try heatin it up a little? heat always makes stuborn stuff agree a little more
The fittings are 13mm. I used a 1/2" (12.7mm)line wrench on mine. It take a little more work to get the wrench on the fitting, but it fits much snugger. That should help keep the wrench from slipping off and rounding the fitting. When mine finally broke free, I would swear that it simply snapped off the pipe, because that is about the sound that it made. It was a loud "CRACK!" and then it was finger tight. It is just about ridiculous. WTF do they put them in with?? Anyway, a little heat might help. After all the sensor can handle like 1800 degrees without breaking a sweat. Make sure you put some anti-seize on the fitting before you install it in your new pipe.
good luck |
i had the same problem but i rounded mine off so we tried to lower my exhaust a little to get to it easier and the whole thing came down to fast and ripped the wires out of the sensor so i called john cobb at cobbs diesel and he gave me the part number so i ran to ford and got another one and put her in the new exhaust and she was good to go ha ha
I took the entire DPF/Cat out with the sensors in place the first time. It took some careful work to get it out without damaging the sensors though. Then I could work on it on the shop floor. Now, I have the sensors anti-siezed, and I didn't put them back in 6-foot-cheater-pipe-gorilla-tight. Now I remove them on the truck, then take out the DPF/cat. and vice-versa.
Also, I said line wrench, but actually it was a crow-foot wrench and a 3/8" breaker bar. It is a bit stronger looking than a line wrench. |
www.CobbsDieselPerformance.com
For about $75 you can just get another sensor and not have to worry about taking the old sensor out. Some of the early Job 1 trucks actually had that sensor cross threaded from the factory, and then add 20 or 30 thousand miles and those sensors don't come out gently.
Give John a call about the sensor. He'll hook a brotha up. |
I have a ? regarding the pressure sensor, which looks like it has a short rubber hose on a hose barb. Does it slip off the hose barb after being baked on for thousands of miles? or is it tough to get off without breaking it. I dont want to remove the hose barb out of the DPF.
The other 2 sensors were easy to break free on mine, and I antiseized them so when I finally get the delete kit it will be easy to do. |
