Passive security problem - Ford Powerstroke Diesel Forum
Old 03-15-2009, 11:01 AM
2 weeks ago, the truck randomly began turning the check engine and service now lights on and then off. The instrument cluster would work, then randomly shut off as I drove.
I stopped and shut the truck off, and when I tried to restart it, it had power, but would not crank. The security light would just flash at me.
I disconnected the batteries, and after a few tries, got it started. The insturments continued to do the same dance.
I have had the truck waiting to get in the shop since. Does anyone have any guesses what is going on?
I have a DPF-R and had an edge evolution plugged in - but was only using the gauges, not the programming.
Thanks
Old 03-18-2009, 10:58 PM
The truck starts when cold. Once it's warm, the security light just flashes constantly when I try to turn it over.
Somebody help please
Old 03-19-2009, 07:18 AM
Have you tried a different key? Maybe the chip in your key somehow got whacked?
Old 03-19-2009, 07:23 AM
Did you try to unplug the Edge and DPF-R modules and then try to start? Do you have a spare key that you could use to try it? Just to rule out if it is the key, or the on board system itself (sorry begger, I didn't see that you wrote that already)
Old 03-20-2009, 08:15 AM
I tried disconnecting everything - but no luck.
I went to the dealership to get another key cut, but apparently you need two good ones to program the new one....so no luck there.
I had it towed back to the shop this AM. It's making more miles on the hook than on it's wheels in the last couple months. Brutal.
Old 03-25-2009, 01:09 PM
Truck still isn't running....
The dealership is going to replace the computer tomorrow - at my cost of course...the tab on this is beginning to be staggering
Old 03-27-2009, 09:13 AM
If you can believe this......
Wiring that runs through the left front wheelwell shorted, and fried the PCM. Causing all of my issues for the last 3 weeks.
