Gelled up yesterday - Ford Powerstroke Diesel Forum
Old 03-01-2009, 05:42 AM
Send a message via AIM to goXtreme Send a message via MSN to goXtreme
Gelled up yesterday
I couldnt believe it...
It was only -6 and I got out on the highway and made it 11 miles and the diesel gelled.
I am anal about putting the right amount of treatment in the tank when I fill, I fill up at the same place every day, and we (everyone at work, about 35 trucks), fill up at the one store.
I am not worried about that though, I got it back to the shop and changed the filters and I am good to go.
The main question I have is, what is the trick to getting that thing to start faster after you change the fuel filters? It took about 1/2 Hr yesterday to get it running. It has always been hard starting after a filter change but it seems to be getting worse.
Any advice/tips?
Old 03-01-2009, 05:50 AM
Any advice/tips?
Did you let the truck warm up before you took off at -6. I have drove mine at -13 so far this winter. I too am anal about the right amount of additive. I use the Ford anit-gel about 6 ounces per tank....4 ounces treat 25 gal, so 2 more would treat 37.5. I still let it warm up till the temp gauge is half from normal before I take off with it. As for the starting after fuel filter change...in the owners manual, there is a procedure for bleeding the air from the fuel system....sometimes this process has to be done more than once. I don't think it would hurt to drain off from the water seperator as well...just incase there is a little water there. I let the dealer do my filters...I let them do all the service on it. That way all of my service is recorded offically...better trade in value is what I am after. I hope this helps
Old 03-01-2009, 05:55 AM
Yes I let it warm up, everyday, even in the summer.
It ran fine when the temps around here dropped into the -30 range, and it was conditioned the same.
I will look through the owners manual for the procedure for bleeding air.
As far as having the dealership service it, the company i work for pays me for the upkeep on the pickup, so I service it, unless it is inthe shop for repair already, I keep track of everything that is done to the pickup in a little book that I keep in the center console, down to rotating the tires.
Old 03-01-2009, 06:08 AM
i've read that you give it a few key/pump cycles to prime the bowl.
-just like you're glowing it. you'll hear the fuel pump ticking (pumping). let that pump till it stops 2 or 3 times before trying to start it.
after my last filter change i did this and it fired right up after the 3rd pump cycle.
hope that helps/is what you were looking for.
Old 03-01-2009, 06:23 AM
I tried that too, ALOT, and I even took the top filter back out and filled the bowl manually and it still took another 10 minutes.
Maybe next time, (next month), I will fill the bowl, then cycle the pump a few times?
