DTC P1096 Engine oil temp sensor range/performance - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-18-2009, 07:25 PM Thread Starter
Pro Flo's Avatar
I think when my last oil change was done something must of unkooked is this possible cause the EOT on the DD does'nt display or read the oil temp?but I think the stock gauge does....would the dealer have to unhook anything for the oil change( i think not )any Ideas? Thanks
2008 F450 l/b dually 4x4 Lariat Blk/gld
Spartan 275 DPF delete and dual 6" Stacks
22.5" Alcoa Rims
Pro Flo is offline
post #2 of 2 Old 02-20-2009, 06:57 PM
Greenhorn Diesel's Avatar
I have watched my dealer change the oil, and they do not disconnect anything electrical. Did you restart your DD. Mine wouldn't display my fuel rail temp, and I just restarted it and it worked fine.
Brad
2008 Ford F-350 XLT CC, LB, DRW, Job1 updated to Job3, 4.10 gears, 6.4L Powerstroke, White/Pueblo Gold, DeeZee Stainless steel elite cab boards, Spartan tuned(150dpf enables, 150, 210), Flo-Pro DOC/DPF delete AFE Pro Guard 7 both from Cobb's diesel
, B&W turnover ball hitch, cody cushion , Cobra CB with co-phased Silverload 4' whips,
Greenhorn Diesel is offline
