Bearings or brakes? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-16-2014, 07:22 PM Thread Starter
09SDLariat's Avatar
Quoted: 9 Post(s)
Garage
Bearings or brakes?
Hey, I noticed to day while running some errands that there was a loud squeaking coming from one of my wheels. At first it was when I was coming up to a stop light so I though it could have been a stone in the brake pad. Well I got to home depot did my shopping then got back in the truck and drove over to the buger king for lunch, and I squeaked the whole way across the parking lot which was about 2000ft. so when I got to the window the truck squeaked when I put it in park. It kinda rolled back a bit and squeaked when it did. I got out after I got my food and checked the rotors with my hand and they were all the same temp. So I kinda suspected a bearing. But when I pulled out and got up to speed 55mph. It stopped. After I got home which was about 30 miles. Once I got home I again checked all rotor with a thermometer, they were all with in 2 or 3 degrees. Same with the hubs. So that's why I'm perplexed as to the root of the issue, what are ya'lls thoughts. I'm pissed off and hitting the jack, I'll look at it tomorrow.
09SDLariat is offline
post #2 of 7 Old 08-16-2014, 07:27 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I'd be suspecting a u-joint
dhanna6powerstroke is offline
The Following User Says Thank You to dhanna6powerstroke For This Useful Post:
09SDLariat (08-17-2014)
post #3 of 7 Old 08-18-2014, 07:24 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would also say u joint. However, are you sure its coming from the wheels? it could also be a tensioner/idler pulley?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 7 Old 08-18-2014, 06:06 PM Thread Starter
09SDLariat's Avatar
Quoted: 9 Post(s)
Garage
Yeah it was definatly coming from the wheels. When I stopped moving it stopped. That's why I figured something drive line related. I have put about 80 miles on it since and the squeak has gone away, I'm now wondering if it was a stone caught in between the rotor and pad. I had that happen on my 150 but it was a grinding not a squeak.
post #5 of 7 Old 08-18-2014, 06:17 PM
Heavy_GD's Avatar
Quoted: 1440 Post(s)
Feedback Score: 3 reviews
I vote rock
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #6 of 7 Old 08-18-2014, 06:51 PM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
X2 on rock.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #7 of 7 Old 10-12-2014, 08:21 AM
scottylov's Avatar
My 09 is doing the same thing, someone told me it may be a rubber gasket next to the wheel bearing. Mine is coming from the right front. I does it when its been driven a while and its all hot. I spayed some lub into the housing and it stop for a while, but then it would come back after the lub would ware off.
2009 F350 Lariat Loaded LWB 4X4.
4.5 CST lift
KMC XD Series Spy
H&S Mini Maxx
Diamond Eye DPF/Cat Delete
AFE Stage II Intake
scottylov is offline
