6.4 knock/tick - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-02-2014, 07:07 PM Thread Starter
POWERSTROKE_HER's Avatar
6.4 knock/tick
Is this the normal knock/tick some 6.4s have.
2008 f350 crew cab long bed dually zip
197k all stock
Watch "6.4 Powerstroke knock" on YouTube
6.4 Powerstroke knock: 6.4 Powerstroke knock - YouTube
POWERSTROKE_HER is offline
post #2 of 6 Old 08-02-2014, 08:28 PM
That is not normal does it sound like it's coming from the head?
2010 F250 S&B intake, H&S tuned, CAC pipe
larry782 is offline
post #3 of 6 Old 08-02-2014, 08:31 PM Thread Starter
It sounds just like the tsb ford put out regarding the noise. The video makes it sound much worse.
Clip was broken on passenger's side. Rocker foot was missing on driver side. Replaced but noise still there. No lack in power no cel.
post #4 of 6 Old 08-03-2014, 09:39 AM Thread Starter
If anyone has the normal "tick" a video would be great so I can compare the two. I have access to a short block and I have an extra set of heads to build another engine if need be.
post #5 of 6 Old 08-05-2014, 05:18 PM
6.4L Powerstroke with a new ticking noise. - YouTube
Try this one, noise went away when I started using Opti-lube oil fortifier.
Engine been to the dealership since then for a leaking bed pan and several oil changes and they say the noise is fine.
Running a very hot tune for months with snow performance water only with no issues.
You might have a lightly bent push rod or wear on the cam.
GSchretter is offline
post #6 of 6 Old 08-05-2014, 05:20 PM
https://youtube.com/watch?v=EA6El5ouuBI
