Weird boost issue... Help please. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-30-2014, 06:13 PM Thread Starter
Details: 2010. 6.4. 138k, dpf delete, mild SCT tuned, 5" down pipe back exhaust, S&B intake.
Installed all performance parts about 3 weeks ago. Put maybe 600 miles on the truck since then and had no issues or problems. On a return trip from a weekend getaway, I noticed I was "rolling less coal" than usual once I got back into town. Stomped the pedal a bit and saw what I thought was grey smoke. Drove it to the house and parked it. No puking coolant, no thrown codes, oil is good. Waited about 2 hours and walked out to pop the hood, area around the turbo was still super hot. Seemed hotter than normal. Checked around again for leaks, and noticed nothing.
Left it alone for the night, and googled myself into paranoia. Started it up the next day and put the pedal down again. Next to no smoke until the turbo was de-spooling. I figured maybe the boots to the turbo or inter cooler were blown off or cracked so I checked those out. Nothing there either. Again googled myself into paranoia for the night.
Today I placed my cellphone near the turbo to record and check for "rattling or metal on metal noise" and noticed nothing.
I've got next to zero register able boost while in park, and about half the boost I did have when I took it around the block earlier. To me, it sounds like air is bypassing the turbo somehow. I'm losing my mind.
So here I am, begging for help from the wise.
My turner turns off the egr and dpf. Dpf was deleted, I still haven't installed the block off plates for the egr. Can't think of anything I've missed.
Your help and knowledge is appreciated.
o0MEGA0o is offline
post #2 of 6 Old 07-31-2014, 06:12 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Hmm strange. Is there soot on the firewall or soot on the bellows of the up pipes? Take off you ebp sensor and tube and clean it out. You said all the intercooler boots are tight? Can you have someone brake boost while you look for leaks?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
The Following User Says Thank You to 04hdfatboy For This Useful Post:
o0MEGA0o (07-31-2014)
post #3 of 6 Old 07-31-2014, 02:33 PM Thread Starter
EBP sensor and tube are clean now, there were fairly clean. Pulled the MAP sensor and it was FILTHY! Sludge built up all around it and the bung. Tried cleaning the bung as much as possible. Felt like spraying it all out with some carb cleaner. Used MAF cleaner on all the sensors. Is there a better way to clean out the bung and area inside around the MAP?
o0MEGA0o is offline
post #4 of 6 Old 08-01-2014, 01:47 AM
you could also pull the intercooler and see if its saturated with blowby oil.
Current 2008 F250 FX4 6.4L
H&S Mini MAXX, Flo Pro 5'' with DPF Delete, Rudy's EGR Delete, K&N Drop in filter.
US ARMY 2003-Present. Iraq/Afghanistan/Korea
drewactual "
The guys at Rudy's didn't know what to do with me this morning... I thought that was pretty dang funny. " Nobody will ever understand the bond between combat veterans unless they served in combat!
Bear Killer is offline
post #5 of 6 Old 08-01-2014, 06:13 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
What I did was I got some q tips and soaked them in brake cleaner. I then put them in the map sensor bung and cleaned out as much of that crap as I could. Something you might look at to help is a ccv reroute to keep all that crap out of the intake. Also and egr delete depending on if you have emissions testing.
08 F350 cc/sb 4X4
o0MEGA0o (08-03-2014)
post #6 of 6 Old 08-01-2014, 07:25 AM Thread Starter
Well, the boost issues are gone. But I've still got some blue/grey smoke. Gonna pull the lower boot from the intercooler and clean if necessary.
o0MEGA0o is offline
