Small vibration primarily under load. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-24-2014, 08:15 PM Thread Starter
havok209's Avatar
It almost feels its coming from the rear wheels, like a tire is out of balance. I just had them rotated, so I doubt it's that. The rate of vibration is relative to the rate of speed. Not necessarily more aggressive. Don't really feel it while coasting at highway speeds but when I give it throttle, I comes back. At around 35MPH, it can be felt no matter if there's throttle or not. I noticed it after merging on to the interstate under about 45% load. (I'm currently running the Spartan 275EL).
Anything I should check?
08 F250 6.4 CCSB
Spartan 275EL
AFE Stage 2
MBRP 4" DP Back
DPF & EGR Delete
6" Pro Comp
20x12" Fuel Hostage
35x13.50" M/T Baja ATZ
havok209 is offline
post #2 of 2 Old 09-07-2014, 12:52 PM
Quoted: 3 Post(s)
Just had same problem. Long story short check your U-Joints, it will cause a small vibration at certain rpm or speed. Hope this helps.
mm854 is offline
