oil temp crazy high - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-19-2014, 07:28 AM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
oil temp crazy high
First off, my truck has been Spartan tuned for about 60k miles. Knock on wood I haven't had any problems due to the power increase... About 2 years ago I noticed that my oil temperature was not the same as my coolant temperature anymore... Info from Dashdaq unit. Since I put the tuner on the temperatures were rarely more than 2 or 3 degrees difference. All of the sudden its 10 degrees then 20 then 30. I took it to the dealership after returning it to stock condition and they replaced the oil cooler under warranty. After I brought it home I flush the cooling system, put in a new thermostat, and filled it with cat ELC. I also installed a coolant filter. The oil temperature really never settled back down to normal. Oil temp runs about 35 degrees hotter than the coolant temperature. Yesterday I drove the truck on a little road trip to St Louis. Temperature going 80 miles an hour was about 260 degrees. My coolant temperature was under 200.
Could something have immediately clogged my new oil cooler. Could there be a clogged somewhere else in the system? 260 degrees on the Interstate without towing is outrageous.
I wrote this with speech recognition while driving. Sorry if it doesn't make sense in places!
sjl2725 is offline
post #2 of 5 Old 07-19-2014, 07:36 AM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 476 Post(s)
Yes something did immediatley clog the cooler....it was the coolant flush. You should do that before you replace the cooler because it IS going to loosen up trash and everything loosended in front of the cooler will stick in the cooler. Essentially, not to be mean, but you wasted a cooler doing the flush afterwards. Time for another one and put in a coolant fiter while your at it.
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is online now
post #3 of 5 Old 07-20-2014, 08:44 PM Thread Starter
sjl2725's Avatar
Quoted: 3 Post(s)
Makes sense. I think I had the cooler replaced first because I didn't want to deal with the dealership insisting they put different coolant in it than the ELC that I wanted in it.
FWIW, I installed a coolant filter after I had the oil cooler installed. Also FWIW, I don't understand how it could possibly work because it doesn't actually filter "everything" "all of the time". it just takes leftover from the heater core supply (or discharge, can't remember) and goes through the filter. I know I'm not explaining it how my brain is thinking it...
So. Can an oil cooler be replaced without taking the cab off? I know its a big job... But its summer and I can ride my harley while I work on the truck.
sjl2725 is offline
post #4 of 5 Old 07-21-2014, 07:36 AM
Anti-Hashtag Member
Quoted: 476 Post(s)
Ive watched my coolant, i have constant flow through my degas bottle so I imagine that it works on the premise of that.
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #5 of 5 Old 07-21-2014, 08:29 AM
superduty6.4's Avatar
That's correct that it doesn't filter all of the coolant on a pass. It's just a bypass filter so it would take a few circulation to actually filter all the coolant. With a filter right in the circulating system you would really have to be careful because if it ever did plug, the system would be dead ended. I'm assuming this is why we use a bypass style of tie in.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
