2010 F350 6.4LTR DIESEL WONT START! - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By DAF1963
post #1 of 5 Old 07-06-2014, 12:08 PM Thread Starter
Unhappy 2010 F350 6.4LTR DIESEL WONT START!
Hello everyone, I have a 2010 f350 with the 6.4 turbo diesel, the other day I was driving down the interstate pulling a trailer and the truck shut off, it was just like you turned the key off. Then I tried to restart it and it wouldn't turn over or anything, had lights and power to everything. Well I got it home and ran my code scanner on it and it came up p0087 code low fuel pressure rail? Also the fuel pump relay fuse (20amp) was blown I put a fuse in and it started up and ran fine for 2 days, then it blew the same fuel pump relay fuse again? If anyone has ran across this in the past I would like an idea where to start.
Thanks Dave.
DAF1963 is offline
post #2 of 5 Old 07-06-2014, 12:11 PM
Tennessee Powerstrokes
GoFastPadre's Avatar
Can;t be of any help but Welcome to the Addiction I mean org!!
To reach GoFastPadre
Official Chapter Area
GoFastPadre is offline
The Following User Says Thank You to GoFastPadre For This Useful Post:
DAF1963 (07-07-2014)
post #3 of 5 Old 08-10-2014, 08:01 AM
Quoted: 2 Post(s)
Figure it out? I would imagine you need a new fuel pump if you keep blowing fuses for the pump.
honemch is offline
post #4 of 5 Old 11-15-2014, 08:36 AM Thread Starter
Yes i finally found the problem!! I had a cab off repair at the ford dealership for the exhaust manifold bolts. So i found under the drivers side inner wheelwell the wire harness was not clipped back down, so it wore thru the wires rubbing on the bracket creating a short intermittantly.Unfortunetly for a 50 cent clip this cost me hundreds in towing and months of searching for the problem. Hopefully this will help someone else in the future.
08SD1961 likes this.
DAF1963 is offline
post #5 of 5 Old 11-15-2014, 09:28 AM
Ez
Quoted: 23 Post(s)
Garage
damn that sucks, but at least its figured out.
SoBStevens is offline
