Rubbing Noise from left side - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 17 Old 06-16-2014, 05:20 PM Thread Starter
Recently I noticed a rubbing noise when I turn. It doesn't happen often but the front left feels loose. When I came home this afternoon I looked under the truck and this part looks like it shifted an inch. The ring around the axel was also loose.
Can anyone tell me what this part is? What could be the issue?
Taking her in to the mechanic on Wednesday.
Thank you in advance
juicefree is offline
post #2 of 17 Old 06-17-2014, 07:09 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
IIRC that is a dust seal. Not worth replacing unless you have to do ball joints or something else. Ford has an updated design that is better (AC3Z-1S175-A).
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 17 Old 06-17-2014, 07:16 AM Thread Starter
thank you for the response. Yesterday I had notice that the inside of the axel was showing, could it possibly be moving inside?
The truck isn't pulling and is running great, just getting a little rubbing noise when I am making turns. It doesn't happen all of the time.
post #4 of 17 Old 06-17-2014, 07:17 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I don't think so. There is an inner axel seal. All that one does is keep the dust out. Its kind of a lot of labor to fix unless you are doing other things.
08 F350 cc/sb 4X4
post #5 of 17 Old 06-17-2014, 07:34 AM
Heavy_GD's Avatar
Quoted: 1311 Post(s)
Feedback Score: 3 reviews
put some grease on that seal and push it back in. Thats not your issue, so dont let your mechanic sell you on it.
Get it to a shop that is good with alignments and have it checked out.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #6 of 17 Old 06-17-2014, 07:41 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
Both my dust rings are dangling! haha. I aint going to worry about it like they the above stated. Unless there something else to be done
Big_Smokey is offline
post #7 of 17 Old 06-17-2014, 07:55 AM Thread Starter
Thank you guys for all of the input. I'll bring it into the shop tomorrow and grease that ring and push it back in. It doesn't feel like anything major.
post #8 of 17 Old 06-17-2014, 08:02 AM
ZMANN's Avatar
Quoted: 1338 Post(s)
I haven't seen the new style dust seal pop out like that before
you might have a unit bearing issue ? have them check
We Miss you Ronnie
ZMANN is offline
post #9 of 17 Old 06-17-2014, 08:09 AM Thread Starter
Thank you. It does sound like a bad bearing when the rubbing sound comes and goes. I'll be sure to let him know when he is looking at it.
post #10 of 17 Old 06-17-2014, 08:18 AM
ZMANN's Avatar
be prepared a unit bearing is costly
aftermarkets are available but most of us like the OEM Timken brand
just try to source the Timken at other than a dealer
you can jack up the truck and see if that wheel has slop while you rock the tire
Heavy_GD likes this.
We Miss you Ronnie
ZMANN is offline
