A/C Problems with No Defrost - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-11-2014, 07:59 PM Thread Starter
Reiter77's Avatar
I have the digital thermostat controls in my truck but when i select defrost the air won't come out of the top vents in the dash but when i select the middle vents i can feel the air more as if the actuator is working but the feet is weak also. what part is this? I did a little research and found these year trucks don't run the A/C off the vacuum system anymore.
2008 F250 CCSB Lariat 6.4 4x4 Mini Maxx 5" Straight Pipe Flo-Pro EGR Delete Toyo 35s 22x11 XD Diesel Black Color Matched Bumpers 5% Tint 35% Windshield
2005 F250 CCSB Lariat 6.0 4x4 ARP studs, Edge Juice Platinum, 6.4 Banjo bolts, Blue Fuel spring,
Reiter77 is offline
post #2 of 7 Old 06-12-2014, 05:11 AM
Quoted: 9 Post(s)
Most likely one or more of your blend doors is acting up and not working properly. As far as which one...hmmm good question...maybe someone else who's had the problem will chime in.
tofer is offline
post #3 of 7 Old 06-12-2014, 05:55 PM Thread Starter
Reiter77's Avatar
I took a look at the diagram and I see three motors for the dual zone ac. Anyone with any experience replacing these?
Reiter77 is offline
post #4 of 7 Old 06-15-2014, 01:46 PM Thread Starter
Reiter77's Avatar
Bumppppppp
Reiter77 is offline
post #5 of 7 Old 07-01-2014, 06:28 AM Thread Starter
Reiter77's Avatar
no one can help?
Reiter77 is offline
post #6 of 7 Old 07-18-2014, 02:45 PM Thread Starter
Reiter77's Avatar
bumpppppppppp
Reiter77 is offline
post #7 of 7 Old 07-19-2014, 05:14 AM
Ranzan's Avatar
Quoted: 22 Post(s)
There are 2 blend door actuators on these trucks with the dual climate controls
One is at the base of the dash in the center which is easy to spot if you look up underneath
The second one is buried behind the radio and is only accessible by removing the pass side air bag , radio and vent tubes
To check and see if you have actuator troubles
Run a self diagnosis of the system by pressing and holding the defrost and off controls release and hit the auto button within 3 seconds
And the end of the test it will list a code if there is a problem
22 66 is the actuator code
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
