COOLANT PROB - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 21 Old 06-02-2014, 07:29 PM Thread Starter
TxBoyJay's 08 KR250's Avatar
Unhappy COOLANT PROB
had my radiator w/hoses degas bottle with hose replaced from the dealer, got it back and was going WOT, pulled and degas bottle was empty and coolant everywhere!!!!!
took it right back to dealer 30mins later and was told my fan clutch was bad and it was causing the other cooling parts to work harder, therefore my coolant pressurised and went everywhere, the shop foreman came out and talked to me and he loosened the degas bottle cap and let the pressure out once he did that the coolant started to bubble up and refill up my degas bottle..????
i had just had my fan clutch replaced 8/2013 for they went ahead and replaced it for me again under previous warranty.
But since i've had it back i'll drive around for awhile, pop my hood and notice my degas bottle low, until i loosen the cap and let the pressure out than starts to bubble up and fills my bottle back up, also kind of noticeing some limpness to the truck???
SO MY QUESTION IS, WHY IS IT STILL DOING THIS???? I WAS ALSO TOLD BY THE FOREMAN IT COULD BE AIR IN THE HOSES/LINES... :dunno :dunno
i called the service rep who helped me, on sat and left a msg but hasnt gotten back to me...
HELLLLLPPP!!!!
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
post #2 of 21 Old 06-03-2014, 07:46 AM
Quoted: 8 Post(s)
How far have you driven since degas bottle and stuff was replaced? It'll take a few miles to bleed air out of system and you'll have to add coolant as air bleeds out.
Heavy_GD likes this.
tofer is offline
The Following User Says Thank You to tofer For This Useful Post:
TxBoyJay's 08 KR250 (06-03-2014)
post #3 of 21 Old 06-03-2014, 09:20 AM
Snowboarder7710's Avatar
Quoted: 5 Post(s)
mine does the exact same thing. im deleted and have egr block off plates. the coolant would return to the degas bottle only after i blocked off the egr. before, when it was stock it wouldnt come back. i havent had any cooling problems towing or performance issues though. the degas is also pressurized when i unscrew the cap. ive searched and searched and havent been able to find an answer to it.
Snowboarder7710 is offline
The Following User Says Thank You to Snowboarder7710 For This Useful Post:
post #4 of 21 Old 06-03-2014, 03:45 PM
VI.IV's Avatar
The system is supposed to be pressurized i thought? If coolant was everywhere after driving maybe coolant cap is bad?
Try replacing it. But keep in mind your truck might start leaking at the radiator if hasnt already my rad did.
check this out i saw it a while back.
2010 KR 250 CCSB, DD 275EL Spartan, Deleted couple things, K&N, No motorcraft fluids, all filtered. Hoping lift and wheels soon.
VI.IV is offline
post #5 of 21 Old 06-03-2014, 04:27 PM
CowboyCody's Avatar
Something dosent seem right, I have never noticed mine moving much. Maybe a couple inches or so on the side of the bottle. Are you sure it's full? How old is your cap?
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #6 of 21 Old 06-03-2014, 06:46 PM Thread Starter
almost a week, maybe 150miles
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
post #7 of 21 Old 06-03-2014, 06:50 PM Thread Starter
https://www.youtube.com/watch?v=xM38rFuI_YE
well it only leaked b3fore they replaced my fan clutch... it hasnt leaked since i dont think, its still dirty from the last time the coolant went everywhere i need to clean under the hood and keep an i on it. But my fenderwell definitely hasnt had coolant on since than either..
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
post #8 of 21 Old 06-03-2014, 07:05 PM Thread Starter
if its the factory ford one, and it didnt get replaced along with my new degas bottle. i'm not sure than, my truck has over 170kmiles so it might be stock...
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
post #9 of 21 Old 06-03-2014, 07:36 PM
CowboyCody's Avatar
I would go to auto value or napa and get a new cap that dosent click when you tighten it that has the big spring in it. (Stant or balkamp) And I would fill it up and drive it nice for a while and see what happens.
The Following User Says Thank You to CowboyCody For This Useful Post:
post #10 of 21 Old 06-03-2014, 07:46 PM
VI.IV's Avatar
^^ what he said. And like i said my radiator started leaking right after might want to keep an eye on that. especially if you are using caterpillar coolant like i am, it gets expensive after a while. I preordered the Alradco Radiator coming out.
VI.IV is offline
The Following User Says Thank You to VI.IV For This Useful Post:
