6.4 ac problem please help. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-02-2014, 11:02 AM Thread Starter
Quoted: 39 Post(s)
Bought the truck recently and noticed it needed little freon but still blew cool. Drove truck yesterday and just blew air. Looked and ac compressor isn't engauging. Tested the clutch and it clicks so the compressor is good it's just not getting any power. Is there a fuse or anything? Any input would be great!
2008 f250 king ranch ccsb: under construction
blacksmoke powerstroke is offline
post #2 of 10 Old 06-02-2014, 11:08 AM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
if it has a leak it may be to low to come on.
GD
Heavy_GD is offline
post #3 of 10 Old 06-02-2014, 11:29 AM Thread Starter
Quoted: 39 Post(s)
We put freon in it today and it didn't even take the whole bottle and still won't come on.
post #4 of 10 Old 06-02-2014, 06:38 PM
TxBoyJay's 08 KR250's Avatar
mine was doing the same thing when i first bought it, my compressor was leaking, so the dealer told me.
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
post #5 of 10 Old 06-04-2014, 04:02 PM
Im pretty sure PCM controls power to clutch. The PCM may not send power to the clutch if it sees a switch that is out of parameters. Might have a bad cut-out switch, etc..
Scumbag is offline
post #6 of 10 Old 06-04-2014, 04:37 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Does it only do it while idling or when you are driving down the road.
if i idle it turns to blowing coolish air. then when i get out on the highway its real cold again.
Big_Smokey is offline
post #7 of 10 Old 06-04-2014, 05:23 PM Thread Starter
Quoted: 39 Post(s)
does not blow cold at all!!! ac clutch will not engauge!!
post #8 of 10 Old 06-04-2014, 05:55 PM
WinnerWinner's Avatar
Do you have digital controls?
WinnerWinner is offline
post #9 of 10 Old 06-05-2014, 05:01 AM Thread Starter
Quoted: 39 Post(s)
no I have the manual controls
post #10 of 10 Old 06-07-2014, 03:52 AM Thread Starter
Quoted: 39 Post(s)
ended up fixing it. went to my dealer and they printed fuse diagrams and wiring schematics and I replaced all fuses and swapped relay and did nothing. turned all climate controls to off, hot, low then max, cold, max and pushed ac button that was already on and it worked. I now have ac again. thanks guys
