Blown Up Pipe... Questions. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-28-2014, 03:57 PM Thread Starter
I after hearing a loud exhaust leak and increased EGT's I crawled under the truck and found the driver side up pipe blown at the bellow. I was hoping it was the EGR pipe but it wasnt... So I have a few question...
I was quoted the following:
6.0 manifolds and up pipes: Anywhere from 2700 to 3500
6.0 manifolds, up pipes, oil cooler, and studs: 6000
Truck only has about 44K miles on it. Had the HPFP replaced a few thousand miles ago. My first question is about the pricing on the quotes, do they seem fair? Good reputable shop.
Do I need to do the oil cooler? I can see maybe a remote cooler or something, bot really educated on oil cooler issues.
I have right at about 6-7 grand I can spend. But since I'm going to have to get the cab lifted and everything I'd like to do the manifolds, up pipes, studs, and probably a 71 mm...
What do you guys think?
2008 Ford F-350 CC/LB 4X4
Hoosierdiesel is offline
post #2 of 4 Old 05-28-2014, 04:54 PM
sanman28's Avatar
I think your getting hosed.....and you dont need 6.0 manis. Look at the prices for the parts with Elite Diesel. Cab removal/install costs me $650.00 from my local ford dealer. I would do studs, new 6.4 up-pipes, and a 71mm turbo with your money......and still have some left to start your transmission build.
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #3 of 4 Old 05-28-2014, 06:24 PM Thread Starter
Looks like i can get turbo, studs, gaskets, up pipes for around 3 grand, about 2200 once I get my core refunds. Just have to talk to my local dealer and see what he thinks.
post #4 of 4 Old 05-29-2014, 07:22 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That is a a lot for those parts. Check out Rudy's or dark horse diesel for the up pipes. As stated 6.0 manifolds are not needed but I do recommend them for reliability and flow. I have pics of how bad the 6.4 manifolds are. I would say studs, 6.0 manifolds, up pipes, ported intake manifold and a 71 or 72 turbo. You can find 6.0 manifolds for cheap in the for sale section.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
