overheating and feels sluggish - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-27-2014, 05:57 PM Thread Starter
ajordan6337's Avatar
Truck keeps overheating when run for a little. Does it often for big hills. I know the EGR leaks and I can't seem to keep the coolant from running out. It's also losing power. Doesn't feel as strong as it should. Any ideas whats wrong?
08 F-250, 6.4, King Ranch, captains, ccsb, 8 inch rough country, 37's on 22' monsters, volant intake, sct livewire innovative tunes, 5 inch turbo back flo pro, top gunz customs control arms, Iron bull
07 Mustang, GT/CS, LT's, Custom 3inch Straight Pipes, 20 inch Razors, Spector
11 F-450, 6.7
ajordan6337 is offline
post #2 of 3 Old 05-27-2014, 06:09 PM
7Tree's Avatar
Hopefully it is not your headgasket. Do you have coolant/water in your oil? Do you have exhaust gas blowing out radiator fill cap? I would look for leaks and fix them first. I know you said your egr leaks but I assume your lose of coolant suddenly got worse and your lose of power happened at the same time. Hopefully so more people will jump in and throw some trouble shooting methods out there.
7Tree is offline
post #3 of 3 Old 05-27-2014, 06:14 PM
7Tree's Avatar
Could be your radiator cap. On a turbo charged engine. If you have a leaking headgasket. You will blow antifreeze out the cap under boost.
7Tree is offline
