AC blowing hot air help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-19-2014, 10:11 AM Thread Starter
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
08 6.4 rest in sig.
Drove to the ranch yesterday and had the defrost on running at 70 in the morning then around noon I switched to 60 degrees regular AC and it started blowing hot air....any ideas besides broken compressor
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #2 of 5 Old 05-19-2014, 11:04 AM
Sounds like the blender door actuator. There are several threads about them. 3 in the dash. Looks like kinda a pain the butt. On the other hand they are only about $25 each.
2008 F350 King Ranch 6.4L , 6" RC lift, SCT Livewire Extreme
zpi28 is offline
post #3 of 5 Old 05-19-2014, 11:05 AM Thread Starter
Quoted: 14 Post(s)
I can still change from defrost to floor to dash no problem but it just blows hot
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #4 of 5 Old 05-19-2014, 09:44 PM
Look at the compressor when the ac is running and see if it is cycling. It is a pain to see it, a flashlight helps. If it is not running the compressor, you will need to check the refrigerant pressure. If it is too low, the compressor won't run. If it is on the verge of being too low, it will not work in extreme heat, but may work in the morning when the heat is not so bad. If the pressure is good, then it could be an electrical problem somewhere. You would have to see if the compressor is getting power when it is turned on at the ac panel. If it is not, then check fuses, high and low pressure switch, wires, etc.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #5 of 5 Old 05-20-2014, 12:06 PM Thread Starter
Quoted: 14 Post(s)
Just got it back one of the pressure hoses broke off and leaked all the freon out. New hose installed and system recharged and good to go.
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
