Reduced Engine Power - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-13-2014, 06:00 AM Thread Starter
Howdy guys...
I just purchased my first diesel...it's an '08 F250 with about 120k miles. Everything is stock on it. While driving the truck on Sunday it went into Reduced Engine Power (Limp Mode). It actually threw two codes - Exhaust Temperature Sensor Bank 1 and that the engine had too much oil. I changed the sensor yesterday and checked the oil level. Oil level was fine.
Last night I went drive the truck and it went back into reduced engine power. The truck blew a good bit of white smoke. The check engine light would not come on so I wasn't able to pull a code. I noticed that the exhaust tips seem to have a little bit of diesel on them.
Any suggestions??
thinblue86 is offline
post #2 of 2 Old 05-13-2014, 07:22 PM
Sounds like you have an issue when the truck goes into regen mode. Easiest way to fix and extend the life of your truck is tune and delete it.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
