Loosing coolant only under towing load - no overheat, not EGR - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-10-2014, 07:21 PM Thread Starter
I have a 2008 F450 with 6.4L Powerstroke engine. It was losing coolant at a rapid rate – a gallon of mixture in less than 100 miles, probably especially when towing. The Ford dealer pressure tested and determined that the EGR coolers were bad, and replaced both. After that, the truck continued to lose coolant. I determined that if I was driving without tow load, it would not loose coolant. However, when loaded with my 36 foot LQ horse trailer, it would begin to lose coolant immediately. After 12 miles of loaded towing over moderate hills, coolant would be spattered all over the coolant bottle, and the level would have dropped out of sight. The Ford dealer couldn’t figure out what to do. I took it to a diesel shop and they changed the reservoir cap, cleaned the radiators (no help) and then recreated the problem on a dynamometer. On the dynamometer, under no load, the coolant system has normal pressure. When loaded, the coolant pressure climbs to above the level that the cap would release. The coolant temperature stays in the normal range under all conditions, and the radiator entry and exit temperatures confirm that the radiator is working a coolant is flowing. So, in summary: only under towing load, coolant pressure rises to the release point, but there seems to be no temperature problem. No white smoke, no water in the oil. Dumping a gallon of coolant for 100 miles of driving. What next? We’re going to pull the heads but we’re not sure that we will find the problem there. Think this is a good idea? What to look for?
Kim Ross is offline
post #2 of 7 Old 05-12-2014, 06:22 AM
Quoted: 9 Post(s)
Could be head gaskets.....pressurizing coolant system under higher boost values while towing would be my guess.
tofer is offline
post #3 of 7 Old 05-12-2014, 10:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Agreed. It sounds like head gaskets.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 7 Old 05-12-2014, 10:07 AM
Quoted: 48 Post(s)
another vote for head gaskets
drunk on diesel is offline
post #5 of 7 Old 05-22-2014, 08:50 AM
TxBoyJay's 08 KR250's Avatar
+1....... ... ....
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
post #6 of 7 Old 05-27-2014, 08:52 AM
CowboyCody's Avatar
Quoted: 3 Post(s)
Mine was doing the same thing, it was stretched TTY bolts which led to gasket failure. It was fine empty, it would loose a little towing easy, if you pushed it it would puke over a gallon easy.
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #7 of 7 Old 11-24-2014, 03:05 PM
BTM
I have the same thing going on now for over a year. I need to get it fixed. Do you install better head bolts and or gasket? Since fixing your head gaskets, no more issues? What the job run? $6K range?
Brad
BTM is offline
Tags
coolant loss , towing
