Airbag code 51, where's the ACM? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2014, 12:39 PM Thread Starter
Airbag code 51, where's the control module located?
I got the airbag code 51: internal fuse blown. But I don't know where is the restraints/airbag control module located?
Any advice so I can get the module out to be repaired. I suppose I can solder a new fuse to it ..
(6.4 powerstroke)
rammi is offline
post #2 of 4 Old 05-04-2014, 02:12 AM Thread Starter
Found it by myself. It is located under center console between front seats.
Has anybody soldered a new fuse to it? Is there instructions somewhere?
rammi is offline
The Following User Says Thank You to rammi For This Useful Post:
Heavy_GD (05-04-2014)
post #3 of 4 Old 05-06-2014, 02:49 AM Thread Starter
Anybody?
Is the fault code 51 really the "internal fuse blown" or something else? Because I tried other module from other truck and it shows the same fault code 51. But that module is working perfectly on the other truck... So I'm thinking if the problem is not in the module, but where could it be then?
rammi is offline
post #4 of 4 Old 05-07-2014, 09:44 AM Thread Starter
Found the problem. It was not the module as I already mentioned. The problem was in the driver's seat belt retainer: there was two wires going into the retainer and one of them was cut.. I soldered it back together and no more blinking airbag light
rammi is offline
