White smoke after delete - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-30-2014, 10:27 AM Thread Starter
Quoted: 2 Post(s)
Hey guys, just did a dpf delete over the weekend. Truck was running great just cruising down the road, but when I went to give it some throttle (a little over halfway) turbo spooled up to almost 40 and then truck went into limp mode, and started blowing white smoke everywhere. I'm using the dpf-r 4.0 with no additional horsepower tune (I know this isn't the best option, but at the moment its all I could afford..) I do not have egr block off plates installed and gearbox z is saying this is the problem, anyone out there have any ideas? I'm just not buying the block off plate solution..
DBoat1991 is offline
post #2 of 17 Old 04-30-2014, 05:06 PM
I have the DPF-R 4.0 installed also. No EGR block off plates yet. I have been running this way for about a month now, and have not experienced a problem like this. Did you get a CEL? You can read any codes with the DPF-R.
jab108 is offline
post #3 of 17 Old 04-30-2014, 05:08 PM Thread Starter
Quoted: 2 Post(s)
Only code it was reading was P1000 then asked if I wanted to reset all DTC's
post #4 of 17 Old 04-30-2014, 05:25 PM
P1000 is normal after tuning from what I have read. Did you check under the hood? Are you leaking coolant anywhere?
jab108 is offline
post #5 of 17 Old 04-30-2014, 05:28 PM Thread Starter
Quoted: 2 Post(s)
No coolant loss that I have found. I'm almost wondering if it isn't overloading on fuel. Maybe a bad tune from the tuner?
post #6 of 17 Old 04-30-2014, 05:37 PM
I could be wrong (I'm no mechanic), but I think that if it was overloaded on fuel, the smoke would be black... How much have you driven the truck since you did your deletes? You can always revert back to stock - don't start the truck, and reload the tune. Are all of your sensors plugged in? They don't have to be back in the pipe, just make sure they are all plugged in.
jab108 is offline
post #7 of 17 Old 04-30-2014, 05:42 PM Thread Starter
Quoted: 2 Post(s)
Yes I have all the sensors plugged in, they aren't in the pipe, and I did the revert back to stock and reload the tune (it was the only way I could get it out of limp mode. Tune has been on for about 4 days now
post #8 of 17 Old 04-30-2014, 05:48 PM
Ok. Is the truck running OK now? I did a quick search and found that the EGR valve may be a cause. Also, was it raining or humid? Some people have reported that their truck blew white smoke during rainy or damp conditions. Do you have the option for the economy tune with the DPF-R? ( the 4.0 + model). I believe that tune shuts off the EGR valve.
jab108 is offline
post #9 of 17 Old 04-30-2014, 06:03 PM Thread Starter
Quoted: 2 Post(s)
Truck will run ok until I get on it again, this has happened three times now. And my tuner does not do any Hp increase, I wasn't looking for added power, only more reliability haha, looks like that got me far!
post #10 of 17 Old 04-30-2014, 06:12 PM
Oh man, that sucks!! What year is your truck? Is it possible that you have some water condensation in the inter cooler pipes? Since my mechanical abilities and knowledge are severely limited, i'm running out of ideas... I'm not sure that I buy the whole EGR block off plate solution either...I did run the stock no DPF tune for a while and towed a 14k trailer with it. My boost was up there a few times also, and I didn't have that problem, and I haven't got the EGR plates yet.
jab108 is offline
