Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum
Old 12-16-2008, 06:25 PM
blackvelvet blackvelvet is offline
Exclamation WONT START!! and I need it
Hey fellas, I am in ND right now at work and my pickup has been sitting for 6 days, tempatures have dropped around -30 to -50
the story....yesterday i figured since its been sitting for a while i should start it and let it run for a bit bein its been so cold and it fired right up (been plugged in) i ran it for about 45 min and shut it down----today i fired it up came back 15 min later and it wasnt running and WOULD NOT START, it cranks fine but wont start......there is a warning light on the dash in the shape of a wrench and in the manual it says powertrain malfunction/reduced power/electronic throttle control (RTT)
Im supposed to leave in the morning but i cant get the son of a b*tch to start HELP PLEASE!!
Old 12-16-2008, 06:32 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
could be alot of things , is it possible the fuel is gelled
Old 12-16-2008, 06:36 PM
if this is the case, and in 1 hour it will start and i take off down the road will it shut down and leave me stranded
do these sensors go bad often, i have less thank 5k miles no previous problems job 3
Old 12-16-2008, 06:38 PM
i went back and reread the thread , you are saying it only didnt start after it had sat , i had understod it to say , it ran for 45 minutes and then didnt restart , sorry if i rear wrong
Old 12-16-2008, 06:42 PM
no you read it right the first time, yesterday i ran it for 45 min with no problems, and today i fired it up it seemed to be running fine and then i went inside for 15 min came back out and it was off
dont think fuel is gelled up, have fuel conditioner in it
Old 12-16-2008, 06:45 PM
ok , is it still plugged in , is the check engine light on
Old 12-16-2008, 06:52 PM
ya its still plugged in, no check engine light but a wrench will come up and then the engine oil light
Old 12-16-2008, 06:59 PM
CobbsDieselPerformance CobbsDieselPerformance is offline
The wrench is the Check Engine Light.......
Old 12-16-2008, 07:00 PM
with a 6.4 its almost impossible to diag anything without a scanner , im afraid you have high pressure fuel pump issue , dpf sensor problem or high pressure fuel pump wiring or sensor on pump , like i say it could be so many things , where are you in ND, how close are you to a dealer
and by the way , im glad to see somebody from out that way on the site ,dont see many , im familiar with that area , i just got back from hunting in the ekilaka area , and camp crook south dakota , came thru billings back in july on our way to redlodge to the bike rally out there , dont pass to many newer trucks when im out there , just mostly old reallky dirty ones
Old 12-16-2008, 07:01 PM
the 6.4 has both a green wrench light and also a engine symbol for the check engine light , the wrench light usually means its in failure mode
