2008 F350 6.4L - HPFP and Fuel System - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-14-2014, 01:54 PM Thread Starter
"Reduced Engine Power" message came on and truck went into limp home mode on Friday. Shut it down for the entire weekend, drove it to the local dealership today. I am being told that they have found metal flakes in the fuel system and that my one injector is stuck open due to those metal flakes. The Diesel Tech is saying that the HPFP is most likely the problem. They are taking the cab off tomorrow to get the the HPFP. He informed me that if they find rust in it that it will not be covered under warranty. I have been reading horror stories about this problem with the 6.4L, that Ford will not warranty it and the repairs range from $5k - $10k+. I just purchased the truck used in late Sept of 2013 with 84,000 miles on it, I also purchased Ford's premium care warranty when I bought the truck (3 years, 36,000 miles bumper to bumper coverage). I haven't even had the truck a year yet, it now has 98,000 miles on it. A week after I bough the truck I had to take it back to the dealership due to a similar problem with the "Reduced Engine Power" message and it ended up being 2 faulty injectors. Fixed with no problems after until now. Does anyone have any insight on this matter??? Will Ford cover the repairs or am I stuck?
J
2008 6.4L F-350 FX4 Super Duty CCSB
2.5" Ready-Lift Leveling Kit, 4" Rear Blocks
35" Nitto Trail Grapplers
18" XD Spy 797 Black Machined Rims
Vico103 is offline
post #2 of 14 Old 04-21-2014, 05:59 AM Thread Starter
Exclamation UPDATE:
UPDATE:
Ford is going to cover all repairs under the Premium Care Warranty I purchased when I got the truck in September 2013. The extended warranty is a bumper to bumper 3 year 36,000 mile warranty. Estimated total repair bill from Ford is $9,500. Truck will be getting an entire new fuel system, thank you Ford for stepping up, renewed my faith in a great auto company. They found no rust inside the HPFP, just very minor pitting along the outside edge. Hopefully I don't ever have to go through this again. Does anyone have any tips on how to avoid a HPFP failure and bad fuel? What additives would you/Ford recommend? I heard 'Diesel Kleen' is pretty good, but I'm weary putting any additives in my truck that Ford doesn't recommend.
J
Vico103 is offline
post #3 of 14 Old 04-21-2014, 06:29 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I use the ford motorcraft additive but diesel kleen also seems to work well. IMO the best upgrade to keep the HPFP happy is an upgraded lift pump (airdog 2, fuel lab) with better filtration.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 14 Old 04-21-2014, 07:17 AM
CowboyCody's Avatar
Quoted: 3 Post(s)
I put 2 stroke oil in every time I fill up, along with some addatives to help with moisture. It may be dumb, but it makes me feel better knowing my pump will have some lubricant even if I get bad fuel. I also try to buy fuel at places I know move a lot so that you have a better chance at fresh fuel.
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #5 of 14 Old 04-21-2014, 08:36 AM Thread Starter
Will an upgraded pump void my warranty? Have you used both additives (Motorcraft and Diesel Kleen)? If so which one would you recommend? Thanks!!!
J
Vico103 is offline
post #6 of 14 Old 04-21-2014, 08:38 AM Thread Starter
What additives are you using?
J
Vico103 is offline
post #7 of 14 Old 04-21-2014, 08:38 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I cant imagine it would void your warranty but I am not certain on that. I have tried both and I like the motorcraft additive better.
08 F350 cc/sb 4X4
post #8 of 14 Old 04-21-2014, 08:40 AM Thread Starter
Fatboy, thanks for the replies!!! I will talk to the Diesel Tech about the pump voiding my warranty. I just want to take all proper precautions to avoid this every happening again, especially once the warranty is up!!!
J
Vico103 is offline
post #9 of 14 Old 04-21-2014, 08:52 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem man. Here is my reason for the better lift pump to help the HPFP survive. If you search around even the remaned fuel pumps from ford are having problems. They are known to leak fuel and some are bad right out of the box. B585Ford is having a hell of a time with his HPFP (check out the thread in the performance parts section). Until a better option becomes available we need to keep our HPFP alive as long as possible.
08 F350 cc/sb 4X4
post #10 of 14 Old 04-21-2014, 10:25 AM
CowboyCody's Avatar
Quoted: 3 Post(s)
It depends on the time of year, in the summer I usually use dieselkleen, but in the winter I use howes or power service antigel.
