Door Code? - Ford Powerstroke Diesel Forum
Old 12-07-2008, 09:18 PM
Door Code?
Does anyone know where to find the code to unlock the doors on the truck? Cannot Find the card and the deal charges way to much, appreciate any help.
Old 12-07-2008, 09:31 PM
http://http://www.powerstroke.org/fo...do-i-find.html
Old 12-07-2008, 09:49 PM
Thanks a Bunch!
Old 12-07-2008, 10:02 PM
no problem
Old 12-09-2008, 10:32 AM
I'm in the same situation. I read the posted thread and I can't find the code anywhere under the dash. Has anyone found the code on an 08 yet?
Old 12-09-2008, 11:43 AM
Link didnt work for me Im having the same problem but on my wifes 2008 Ford Edge.
Old 12-17-2008, 05:25 PM
i got an 05 psd and i found it, open the small compartment door by your gas peddle, use a little bit of force to take it off the plastic so that it hangs all the way down. this is the tricky part get a good flash light and a pen and paper. lay down on your back on the seat right in front of the compartment door or near it. slide your body enough to see inside, stick your hand inside the compartment and reach for the insulation behind all the wires, on the wall closes to the motor, use your flash light of course. Move the insulation around , on the wall you will see the code for you truck, make sure your pen and paper are near by to wright the code down, hope this helps
