Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum
Old 12-03-2008, 12:22 AM
MSTR-P MSTR-P is offline
engine light won't go out
Cranked up the truck the other day and the engine light wouldn't go out. Took it to the dealer (no after-market tunes) and he said they didn't recognize the DTC and had no immediate fix for it. I asked him what the code was and he wouldn't give it to me. Stated Ford was researching a fix. Anyone else seen this? Thanks, Mike
Old 12-03-2008, 12:31 AM
rdc rdc is offline
A Former "Turd Brown" Mod
That was certainly unfriendly/suspicious on their part.
Do you know anyone with a reader? It would be interesting to see the code posted up
here. Maybe someone else would recognize it.
Old 12-03-2008, 12:46 AM
no reader
rdc - Unfortunately I don't have a reader nor have any friends that do. I was hoping (not wishing anyone bad luck) that someone else out there may be having this same issue and could help figure it out. Thanks, Mike
Old 12-03-2008, 03:55 PM
rottys rottys is offline
is that on your 08? i would tell them to fix it,if not call ford corp.
Old 12-03-2008, 09:14 PM
on 08
yeh, its on my 08. All the dealer would tell me is that Ford is researching a fix. Should have kept my 04....
Old 12-03-2008, 09:20 PM
gleesonkd gleesonkd is offline
try a parts store or a garage for the obdII reader to read the codes. autozone comes to mind if you have one...
Old 12-04-2008, 06:20 AM
po-po 5.0 po-po 5.0 is offline
they wouldn't tell you what it was!? I know you're in Alaska so this might not be possible....but can you find another dealer? Not telling you whats wrong with your truck is just plain stupid.
Old 12-04-2008, 06:28 AM
Dealer said they didn't know.....
The dealership would not share the DTC with me....as far as the problem, they said Ford was researching a fix for the error. The dealership didn't seem to have a clue about what is wrong with it. However, to answer your question, there are a couple other dealerships in Alaska and I may try the next closest one.
Old 12-04-2008, 07:00 AM
I would absolutely do that. I wouldn't trust any mechanic who was that shady. Not even to do an oil change.
Old 12-04-2008, 07:32 AM
gsracing38 gsracing38 is offline
X2 on going to the parts store...all of them around here will check it for free, they just can't legally clear it. just search the code they give you and let us know.
