Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum
Old 11-22-2008, 04:06 PM
Grewit93 Grewit93 is offline
NEED HELP NEED HELP ASAP!!!!!!!!
Alright guys heres my problem.
My trans temp gauge wasnt working, so i took the pillar down and found that the power wire was pulled off. So i went to put it back on and and stupid me i had the key on still and arched it at the ground by accident. Now my truck wont start or anyhting. I have power at everything it just wont turn over. I looked up the DTC's via sct and i have a B2900. Is this just a fuse or is it a bigger problem?
It's an 08 F-350
Old 11-22-2008, 04:09 PM
outlawdiesel outlawdiesel is offline
fuse
fuse and put the truck in lemp mod
Old 11-22-2008, 04:13 PM
What fuse? I couldnt find any blown. I looked at the one that my gauges are tied into but it looked fine. What do you mean by putting it back into limp mode?
Old 11-22-2008, 04:43 PM
Bump Bump I need help
Old 11-22-2008, 05:09 PM
symbols symbols is offline
Nonsense specialist
I don't know what that code is. I thought they all started with a "P"
I'm not sure about the '08s but if they have a fuse block under the hood you need to check that as well as the one under the dash...
How are you checking fuses?
Old 11-22-2008, 05:23 PM
pulling them out and taking a look at them. I looked at the fuse that the gauges are tied into and it looked good but i wnet ahead and changed it, but still nothing.
Old 11-22-2008, 05:30 PM
Nonsense specialist
Sometimes the can appear good but are really bad. I would get a test light and put the clamp end on a good ground, turn the key on and put the pointy end on each leg of each fuse. If you have one that the light comes on, on one side and not the other, it's a bad fuse. Make sure you don't skip any. Hope this helps.
Old 11-22-2008, 05:58 PM
jamstoyz jamstoyz is offline
check the fuse block under the hood also. those have your bigger fuses in there. its located on the drivers side towards the dash i believe.
Old 11-22-2008, 06:47 PM
Thanks for the help guys
I got it figured out. It was one of the 50 amp max fuses under the hood. And i am not sure why that one blew but its good as new now.
Old 11-23-2008, 07:03 AM
Nonsense specialist
Glad you got it figured out
