Need or Rear driveshaft clicking while Moving? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-18-2014, 03:50 PM Thread Starter
TwinTurbo6.4's Avatar
Quoted: 80 Post(s)
What would cause clicking near the rear of the drive shaft?
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #2 of 4 Old 03-18-2014, 03:56 PM
layson's Avatar
Quoted: 82 Post(s)
Probably a U joint!
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
The Following User Says Thank You to layson For This Useful Post:
TwinTurbo6.4 (03-18-2014)
post #3 of 4 Old 03-18-2014, 04:03 PM Thread Starter
Quoted: 80 Post(s)
That's what I figured. No fitting for it either.
'08 F250
post #4 of 4 Old 03-21-2014, 05:52 PM Thread Starter
Quoted: 80 Post(s)
Just a little closure incase anyone has this issue in the future. It was the U-Joint.
'08 F250
