6.4L No Crank EGT Sensor Codes - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-27-2014, 09:00 AM Thread Starter
Well I got an interesting one in today that I have not seen in years. It has to do with the EGT sensors shorting out or going open and the pcm locking out from starting the truck for 60 min or until it is corrected. This is a unique protection strategy on the 6.4l and there is no indication of this fault in the cluster (no cluster message like the one it shows while engine is running). In this video I show how to get your truck back up and running so you can get it to a shop or home and fix it without a tow bill and how to replace that EGT sensor without breaking it. Hope this helps as this is often a misunderstood no crank concern.
Check out all my Ford Tech Repair Videos @
Please Subscribe. Always something new and interesting!
makuloco2000 is offline
The Following 2 Users Say Thank You to makuloco2000 For This Useful Post:
snoweng40 (12-01-2015)
post #2 of 2 Old 02-27-2014, 12:04 PM
TwinTurbo6.4's Avatar
Quoted: 80 Post(s)
Same thing happened to me a month ago. Ended up not being covered by warranty and a $60 sensor turned into $900.. Needless to say, DPF-r is coming new paycheck.
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
