ticking noise coming from new engine - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-25-2014, 07:12 PM Thread Starter
silver93's Avatar
just installed a jasper remanufactured engine in my truck it has about 500 miles on it and im starting to hear a tapping noise on the passanger side of the truck sounds like it is coming from the valve cover area. you cant hear it really at idle but from 1500 to 2200 rpms you really hear it. sounds to me like a rocker arm clattering or tapping. not really sure. just looking for some input on this issue.also the injectors and turbos are new also
silver93 is offline
post #2 of 10 Old 02-25-2014, 07:15 PM
Powerstroke Techie
It sounds a lot like the noise my truck has been making (albeit mostly from the driver's side on mine) for quite some time now.
Oh......I just re-read your post..... I have not had much luck with jasper re-manufacturing in my experience as a mechanic. Call jasper/the installing shop and ask them to look at it.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 10 Old 02-25-2014, 07:20 PM
Did you put it in or dealer.
If dealer take it back.
If you put it in call Jasper.
Not sure if jasper sells direct anymore.
letitsno is offline
post #4 of 10 Old 02-25-2014, 08:24 PM Thread Starter
silver93's Avatar
no it was installed at a jasper certified mechanic shop.. im waiting to get it out the dealership having a new trans put in it.. this truck has been nothing but a headache in the last eight weeks ive had it.. new motor, injector, turbos and now trans all with in 600 miles of having it.
silver93 is offline
post #5 of 10 Old 02-25-2014, 10:04 PM
srjd's Avatar
Quoted: 2 Post(s)
Sorry to hear about your bad luck hope it gets figured out for you soon. Did you just get it or have it for a while
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #6 of 10 Old 02-26-2014, 05:16 AM Thread Starter
silver93's Avatar
just got the truck been havening it for about 7 weeks. motor went out 12 hours after having it
silver93 is offline
post #7 of 10 Old 02-27-2014, 10:53 AM
someone sold you a truck they knew had issues.
2009 F 250 Lariat 6.4 PSD
cterrebonne is offline
post #8 of 10 Old 02-27-2014, 02:33 PM Thread Starter
silver93's Avatar
yeah bro I do believe that is the case
silver93 is offline
post #9 of 10 Old 02-27-2014, 02:41 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
Mine has made that noise since I bought it.
TSB
09-16-2 6.4L DIESEL ENGINE TICKING/TAPPING NOISE
Publication Date: August 3, 2009
FORD: 2008-2010 F-Super Duty
This article supersedes TSB 08-19-5 to update the vehicle model years.
ISSUE:
Some 2008-2010 F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine may exhibit a random engine ticking / tapping noise that is most noticeable when engine coolant temperature is 185 F (85 C) or higher and from base idle to approximately 1500 RPM. Some customers may complain that this noise becomes more evident after 3000-5000 miles have accumulated on the vehicle or after an engine oil change.
ACTION:
Refer to the Service Procedure for repair recommendations.
SERVICE PROCEDURE
The ticking / tapping noise is most noticeable at the rear of the driver's side front wheel well. 6.4L Powerstroke diesel engines exhibit this normal audible condition (some engines will exhibit greater audible noise due to engine build variations). 6.4L Powerstroke diesel engines are manufactured to tight tolerances in order to meet strict durability and reliability standards.
This noise is caused by the relationship between engine block, crankshaft journals, bearing inserts and oil viscosity / film. This relationship allows a pulsation that resonates through the cylinder block and is heard as a metallic ticking noise. This condition is present on all diesel engines.
Technological improvements and overall noise reduction in today's diesel engines make this issue seem new when in fact it was masked by other noises on previous engines. Other engine manufacturers report similar conditions in their diesel engines. Vehicle testing and engine teardown analysis have confirmed this condition will not effect reliability or long term durability of this engine. Dealers should not attempt to perform vehicle to vehicle noise comparisons. This may lead to incorrect conclusions and ineffective repairs.
NOTE: DO NOT ATTEMPT REPAIRS FOR THIS NORMAL NOISE CONDITION. REPLACING THE ENGINE OR INTERNAL COMPONENTS WILL NOT REDUCE OR ELIMINATE THE TICKING/TAPPING NOISE. PLEASE PROVIDE THIS BULLETIN TO CUSTOMERS THAT INQUIRE ABOUT THIS CONDITION.
WARRANTY STATUS:
Information Only
DEALER CODING
BASIC PART NO. CONDITION CODE
6007 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright 2009 Ford Motor Company
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #10 of 10 Old 03-14-2014, 12:49 AM
corn binder's Avatar
Quoted: 2 Post(s)
wow!! you probably spent 1/2 or better Han wha you paid for the truck
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
