Turbo hiss? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-23-2014, 03:10 PM Thread Starter
kelsapher's Avatar
Turbo hiss?
Hi I just noticed a hissing noise in my cab yesterday, I've check my cac system connections and there all good. You can sometimes smell exhaust in the cab aswell, I looked under the hood and believe the noise is comming from the turbo, I had my brother in law (diesel tech) look at it and he thinks the turbos have a gap? Which might be the issue? But I also just installed a egr delete kit so I'm thinking it may be the driver side manifold? Not sure! Need oppinions!! Thanks!
kelsapher is offline
post #2 of 20 Old 02-24-2014, 06:09 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would guess a leaking up pipe. Check the cross over pipe for soot. Also check the bellows.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 20 Old 02-24-2014, 06:12 AM Thread Starter
kelsapher's Avatar
I will do that thanks!
post #4 of 20 Old 02-24-2014, 06:19 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem. If it is the cross over pipe you can get rid of that pipe and relocate the ebp sensor. If its the actual up pipe you will need to replace. There are companies that make more heavy duty up pipes or you can go with 6.0 manifolds and custom up pipes.
08 F350 cc/sb 4X4
post #5 of 20 Old 02-24-2014, 08:29 AM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
Usually when an up-pipe flex splits it will cause a hissing noise and smell from the back of the engine. I typically see the RH flex split but the others can do it too.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #6 of 20 Old 02-24-2014, 08:36 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
My drivers side has blown twice.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #7 of 20 Old 02-24-2014, 12:36 PM Thread Starter
kelsapher's Avatar
Yes checked it out more today and that's exactly what it was!! Does it require removing the cab or tranny to replace this?
post #8 of 20 Old 02-24-2014, 01:00 PM Thread Starter
kelsapher's Avatar
Could this of cracked because of the egr delete?
post #9 of 20 Old 02-25-2014, 06:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Is it the crossover pipe with the ebp sensor or is it the actual drivers side up pipe?
08 F350 cc/sb 4X4
post #10 of 20 Old 02-25-2014, 06:31 AM Thread Starter
kelsapher's Avatar
I thought the up pipe at first but after looking at diagrams and pics it looks Like it's the flex on the crossover pipe that I put the block off plate on. Thinking of relocating the block off to the main up pipe.
