Battery cable - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-18-2014, 06:53 PM Thread Starter
Lancer250's Avatar
Battery cable
Took truck in for oil change and fuel filters. Now idles rough. Took it to dealer and they put a MAF in it. Didn't help. I took it to Orielly's and one battery tested bad. I replaced both. Found cable on driver side is very corroded. Truck still idles rough. Could the cable be causing this? What could have happened when filters were changed that could have caused this. I do trust my tech and rep but I am at a loss. They did say a couple of the injectors are suspect but they can't fully test due to the delete and mini max. Any ideas??
2011 F250 bone stock CCSB, FX4, PMF traction bars with 4" blocks, PMF 3" front blocks and camber shims, bilstein 5100 shocks.
SOLD!! 2008 ccsb 4x4, mini maxx, s&b cai, flow pro 4" exhaust, mbrp 4" down pipe, Rudy's up pipes, sinister egr deleate, head gaskets, agr head studs, leveling kit, air bags, high idle mod
Lancer250 is offline
