New engine no start, TRIED EVERYTHING - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-16-2014, 08:06 PM Thread Starter
Hey guy, here's my problem, I have a 2008 f250, HS mini maxx, 5" flo pro full deletes, egr delete, CCV mod.
I put a new short block in, engine cranks but won't start, no codes, checked everything, also I have zero High pressure fuel, scanner reads flat 0 truck cranks great but will not even try to fire.
I have 5 psi for my low pressure fuel which is within spec. I've bled the fuel system everyway possible, low side, high side, let the fuel bowl fill up and I still have no fuel pressure from the HPFP. I've been told from a veteran ford diesel tech that even with a completely destroyed pump I should see some sort of pressure from the HPFP. He's done over 60 HPFP on these trucks and has never seen 0 psi
Could it be a PATS issue? I'm beyond stumped. Any help would be great
I've heard of people needing new keys from the truck being dead so long but I dunno?
Chicagostroker14 is offline
post #2 of 5 Old 02-22-2014, 05:18 PM
Powerstroke Techie
If it cranks, it isn't the PATS system.
What are the PCV and VCV being commanded to during the cranking event?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 5 Old 02-22-2014, 05:53 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
Did you at all touch the pump? The gear is an interference fit. If it's not tight it's not going to spin the pump.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 5 Old 02-23-2014, 04:57 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
You are 100% correct I know where your heading. I had 5 factory motors do this. Picked cab back up and replaced hpfp for bad valves. 3 of them ohmed correctly 2of them had valves stuck open.
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #5 of 5 Old 02-23-2014, 05:00 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
One of my friends did his whole job and called me for no start after he was done. I asked him to look at old pump and see if gear was on it. Guess what it was!!!!!!!! Oooops lesson learned.
A/C ASW A/W WINGS
